gas pedal loose?
Old Aug 9, 2010 | 08:15 AM
SharksBreath's Avatar
BANNED
gas pedal loose?
got a 07 type-s a/t n the gas pedal seems loose.
what i mean by this is, (and i'll try and explain this the best i can), at the top of the gas pedal, where your toes would sit, is a small cylinder bar that holds the gas pedal in place <-behind the pedal itself, at the top.
if you grab the pedal, you can shift it from left to right about a 1 1/2" each way.
it seems to me that the gas pedal should be tight and secure, with no play from either side.
anyone else ever experience this issue, n if so, what can i do about it? when i feel around the cylinder with my hands, i cant feel any threaded holes for a screw, or really anything that i can tighten, etc etc.
any help is appreciated. tia
Old Aug 9, 2010 | 11:40 AM
BANNED
anyone...anyone...bueller?
Old Aug 9, 2010 | 12:16 PM
guitarplayer16's Avatar
Adjust the "cable".
https://acurazine.com/forums/3g-tl-problems-fixes-114/gas-pedal-play-718305/
Old Aug 9, 2010 | 12:37 PM
BANNED
^that thread is talking about problems pushing the gas pedal to the floor, and not accelerating right away.
my problem is that there is loose play from left to right, not top to bottom.
i can grab the gas pedal, and move it from left to right, i feel like it should not move at all from LEFT to RIGHT.
pedal goes to the floor just fine, no problems accelerating, just an issue with the pedal shifting from left to right.
Old Aug 9, 2010 | 01:42 PM
Ah shit, my bad.
Do you feel it moving side to side when you drive?
Old Aug 9, 2010 | 01:51 PM
BANNED
not so much...was just cleaning the interior yesterday and happened to feel the gas pedal, then noticed that it can toggle left to right. just seemed weird to me
Old Aug 10, 2010 | 07:12 AM
BANNED
bump.
anyone else know what the problem could be? has anyone else's gas pedal ever been able to shift from left to right a few inches each way? is there something that holds it in place? it's hard for me to tell bc i can only see so much down there in such a tight spot
Old Aug 10, 2010 | 12:03 PM
01tl4tl's Avatar
go to the dealer and ck out another car of your year on the sales lot, or ask the service manager to let you ck a car in the shop
There may be a service bulletin on this- have you looked in the TSB thread?
Doesnt seem like any movement side to side is acceptable- could result in becoming a toyota in a hurry
thats an electrical signal generator, not a `cable` like older TL-gen2 have
fly by wire for gen3
Old Aug 10, 2010 | 03:41 PM
BANNED
tried searching for the TSB thread, can you help me out bro?
i'll take it to the dealer, i'll be calling them this afternoon. thanks for your help
Old Aug 10, 2010 | 04:06 PM
Will Y.'s Avatar
Registered but harmless
It's accessed through the 3G Service Dept thread, and is here:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/.
You have an odd issue that I haven't seen here on AZ before.
Old Aug 10, 2010 | 04:10 PM
BANNED
https://acurazine.com/forums/showthread.php?t=613659.
thanks for the thread...i'll learn how to search properly one day soon...i promise.
odd issue? that's encouraging!
Old Aug 11, 2010 | 07:41 PM
Marx1's Avatar
when i bought my tl used...i noticed that the bottom of the pedal, where it should be stuck to the floor was broken...check if thats the problem...
Old Aug 12, 2010 | 06:37 AM
BANNED
yeah the bottom of the pedal is secure and fine. its just the top of the gas pedal, on the top back of the pedal, where that cylinder holds it in place, i get movement from left to right about 1-1 1/2" inches either way. can't really feel it when driving, but i am taking it by the dealer this weekend to get it looked at.
Old Aug 16, 2010 | 11:44 PM
VQPower37's Avatar
i went and checked my pedal i have the same car 07 type s ... its firm no shake from side to side, so sounds like you may have a problem. is it really moving inches from side to side?
Old Aug 18, 2010 | 06:59 AM
BANNED
hey, sorry i'm just now responding. thought nobody was interested in this thread, so i myself lost interest.
thanks for checking out your pedal on your 07 type-s.
yes, at the top of the gas pedal, where that small cylinder shaped piece is behind the top of the pedal (holding the pedal in place), i get a little movement from left to ride. i can grab the pedal and move it from left to right about an inch or so each way. but i cannot see where anything has snapped off or screw holes missing, etc etc.
for now i just ziptied one side of it to keep it secure. i will end up going to my acura guy and seeing what we can do about it, just haven't had the time recently. maybe this weekend.
Old Dec 18, 2020 | 04:00 PM
5oo5a's Avatar
having the same problem with my 08 TL, how did you find the fix for this?
ITSJESTER
17
Dec 6, 2018 02:29 AM
JDM96specCTR
Oct 17, 2015 01:06 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Skirmich
Oct 1, 2015 12:59 PM
San Yasin
Sep 29, 2015 10:52 AM
