Gas Cap Light On..'07-'08 TL
Old Jun 20, 2011 | 10:13 PM
anionrings's Avatar
My Gas Cap Light keeps coming on at random times saying i need to tighten my gas cap...
i check my gas cap its tighten...why does my light keep coming on? anyone have any ideas??
Old Jun 21, 2011 | 07:48 AM
omnuts's Avatar
2006 TL: WDP/Ebony
^Do you tighten it until you hear a few clicks?
Old Jun 21, 2011 | 09:11 AM
mau108's Avatar
EVAP Canister Purge Valve. (http://techinfo.honda.com/rjanisis/pubs/SB/B09-056.pdf)
I replaced mine couple weeks back and it's gone. Interesting note, the part I pulled off was made in Mexico had a MEX in front of the part number, the part I put on was made in Japan.
Old Jun 21, 2011 | 06:06 PM
el.profe's Avatar
I have the same problem. If car is not under warranty you will be looking at $150 to fix at Acura.
Old Jun 21, 2011 | 08:29 PM
dzionny_dzionassi's Avatar
or you can buy the part for +-80$ and change in 10 minutes by your self.
Old Jun 21, 2011 | 08:34 PM
el.profe's Avatar
Id perfer that. is there a DIY? saves me a trip to the dealer
Old Jun 21, 2011 | 08:43 PM
https://acurazine.com/forums/showpos...2&postcount=34
Old Jun 22, 2011 | 01:05 AM
Will Y.'s Avatar
Registered but harmless
I thought that the evap canister would be covered by the 8 year/80K mile emissions equipment warranty. Warranty would likely apply to OP's '08 TL.
Old Jun 22, 2011 | 01:21 AM
Rick_TL-S's Avatar
They checked mine & said they fixed it, no charge. It's come back a couple weeks later so I'm going to buy the part & change it myself.
Old Jun 22, 2011 | 07:38 AM
el.profe's Avatar
I have an 07. from my understanding its 7 year 70k powertrain. I will call my dealer and find out about the emissions warranty.
Old Jun 22, 2011 | 08:10 AM
mau108's Avatar
This part does not fall under Emissions warranty. Says right on the TSB.
Old Jun 22, 2011 | 09:03 AM
ParaSurfer1979's Avatar
Mine does this too. Im still under warranty so ill send id by acura. Mine does it when thr fuel light comes on.
Old Jun 22, 2011 | 09:45 AM
Will Y.'s Avatar
Yes, you're correct: it just says "Normal warranty" applies on the TSB.
Hopefully that still applies for OP.
Although various other emissions control parts are covered for 7/70 or 8/80 by the emissions control warranty in CA, the only Evap System component covered--7 years/70K miles-- is the fuel tank.
BTW, in order to view any TSB, we have to go to the TSB sticky thread and go through the selection steps before a TSB link will work.
Old Jun 22, 2011 | 08:24 PM
anionrings's Avatar
I tightening my cap till it clicks like 5 times... it occasionally turns on...stays on until i get out of the car loosen the cap and tightening again...
at first it doesnt bother me but the beep beep beep got to me pretty quickly...
Old Jun 22, 2011 | 10:21 PM
chayos00's Avatar
Umm.... you ever thought of just replacing the gas cap? 5-10 bucks.
Old Jun 22, 2011 | 10:53 PM
anionrings's Avatar
i figure it was some kind of sensor...i went to get an inspection...the guy said my gas cap was ok...
but who knows...ill try this route anyways..5-10 bucks? why not??
Old Jun 23, 2011 | 07:28 AM
mau108's Avatar
It's worth a try but I strongly doubt it. Look at the TSB I posted and see if you have the symptoms listed.
Old Jun 23, 2011 | 09:38 AM
anionrings's Avatar
your post on 3 keeps giving me error..link deny
Old Jun 23, 2011 | 09:45 AM
Will Y.'s Avatar
Go to https://acurazine.com/forums/3g-tl-2004-2008-93/acura-servicenews-bulletins-588838/ and follow the directions in red, per post quote below.
THEN click on mau108's link.
Old Jun 23, 2011 | 10:41 AM
J35A8_Party's Avatar
Known issue with the gas tank vent valve. Dealer fixed this for me quickly and for free after I mentioned the TSB.
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
PortlandRL
Sep 14, 2015 12:01 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
