Gas Cap Light On..'07-'08 TL
EVAP Canister Purge Valve. (http://techinfo.honda.com/rjanisis/pubs/SB/B09-056.pdf)
I replaced mine couple weeks back and it's gone. Interesting note, the part I pulled off was made in Mexico had a MEX in front of the part number, the part I put on was made in Japan.
They checked mine & said they fixed it, no charge. It's come back a couple weeks later so I'm going to buy the part & change it myself.
Registered but harmless
Received 1,149 Likes
Hopefully that still applies for OP.
Although various other emissions control parts are covered for 7/70 or 8/80 by the emissions control warranty in CA, the only Evap System component covered--7 years/70K miles-- is the fuel tank.
BTW, in order to view any TSB, we have to go to the TSB sticky thread and go through the selection steps before a TSB link will work.
It's worth a try but I strongly doubt it. Look at the TSB I posted and see if you have the symptoms listed.
Go to https://acurazine.com/forums/3g-tl-2004-2008-93/acura-servicenews-bulletins-588838/ and follow the directions in red, per post quote below.
THEN click on mau108's link.
mau108 (06-23-2011)
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
