The fun times with my noise making 6-speed transmission.
#41
Chapter Leader (NY/NJ)
Sorry for the wait... Car is running! Goes into 1-6 smooth as hell. Driving and shifting is great. No issues there. My only issue now is car does not want to go into reverse all the time even with car off or on. I feel like the car has to be slightly rolling for the shifter to go into reverse. Thinking about it, i think i had this same problem before 3rd gear went out 3+ years ago... I performed a visual on the gear while the tranny was open but i didn't see anything and i didn't really dig deep into it since i honestly forget about it.... Took it out for a spin tonight. 3 piece U-turn was out the question.... I confirmed its not the lockout. I can move the shifter all the way to the right when off or idle. when moving, i cannot. Any ideas? Synchro? shifter arm? Is there a big enough hole anywhere so i could maybe stick an inspection camera into? i've looked at all the pictures and cannot see much... i really dont want to remove and open the transmission up again... If i have to, i think i might just pull the motor out from the top. Removing the subframe and everything sucks when working on the floor. If i had a lift, maybe it'll be different.
#44
so playing around with it, if the car rolls back a bit, the car will go into reverse... Also if I turn off the car and go from 1st or 2nd to reverse, it'll work
#45
I know this is an old thread, but I wanted to say thank you! Recently was driving (not hard) and suddenly got a very similar noise to yours whenever I go into 2nd gear. No other gears make noise and have never had an issue like this. I have been searching YouTube for videos that sound like what I'm hearing and haven't found anything, while your videos sound just like mine. I did a fluid change last weekend and had some silver bits in the drain pan. Been debating on what to do, whether to take the car in somewhere and pay a couple grand or so, or look into a replacement transmission. This write-up, with part numbers and lots of photos, give me some hope. I have done major work like this on other cars before, but not my TL yet. My biggest concern honestly was dealing with supporting the engine while dropping the cradle. I might give this a shot on my own, as I do have a backup car I can drive. So thanks!
InFaMouSLink (07-31-2024)
#46
#47
Transmission Pro
I didn't know this was possible!
#48
Sounds like a semi-'hybrid' version of the 'brotha' method, only bringing things out the top of the engine bay?
Acura TL Builder (07-15-2024)
#49
Reference posts 5 & 10:
https://acurazine.com/forums/2g-cl-p...-swap-1001141/
The following 5 users liked this post by 619rcr:
Acura TL Builder (07-15-2024),
Legend2TL (07-30-2024),
montero65 (07-15-2024),
srg818 (07-22-2024),
zeta (07-12-2024)
#50
Hey guys! First post here, I’ll try not to embarrass myself too much lol.
I’ve been a big Honda and Acura fan all my life, reaching out today on this thread since my little baby, 08 Type-S has similar issues with the manual transmission. 2nd gear has « given up ».
I’m an enthusiast, by no means a mechanic and I thought I’d reach out in here, last summer I called about 10 transmission shops in Quebec, only two touched manuals and when I mentioned I had the 3.5, they both « good luck » lol.
It’s my second car and I’m lacking time and space to take care of this, was wondering if anyone in here had any recommendation as far as repair shops in Quebec or maybe even Ontario, or else I thought I was going to list the car on an auction - with full disclosure.
I love it, doesn’t get out in the winter and has 145,000km on it. If anyone has any recommendations I’d be grateful
montero65 (07-29-2024)
#51
The following 2 users liked this post by 619rcr:
dhammer6788 (07-30-2024),
#52
Main shaft, 2nd gear highlighted
Counter shaft, 2nd gear set highlighted
I actually did the car-part search and found the same transmissions listed that @619rcr posted above. Surprised how many were in Ontario. Not super excited about those costs or having to drive 200+ miles to get a transmission, but realizing my costs to repair it myself could easily reach $1,300, I'm considering this as a possible option instead.
#54
Gentlemen thanks so much for all the details, I should have come here before.
In 7 years of having it I only needed to change the timing belt and water pump and oil (and air filters etc, ofc), I’m so bummed about this lol.
if it’s not in my hands I believe this one could be a long term collector’s
#57
Transmission Pro
The 2007-2008 TL-S 6MT was basically Honda's last hurrah of the 3g TL, 7g Accord V6 that Acura sold during the overlap years of 7g and 8g Accord.
Transmissions have become more specialized. Mechanics , technicians at the Honda / Acura dealerships are (understandably) less compelled to go through the training to work on transmissions when it's something that they rarely will do, or even have the opportunity to do. There's just not that many manual transmission vehicles.
This has lead to the scenario where the convention of addressing transmission issues entails replacing the entire transmission with a salvage transmission. But the problem with that is that there's only two years that TL-S 6MT were even offered. That combined with the face that it's been 16-17 years since one of these vehicles rolled off the assembly line.
So then it becomes a scenario of trying to find a shop that will work on these transmissions, or to DIY.
The problem with that is that if you do find a transmission shop, unless they're already specializing in these particular transmissions, they're going to be limited to the information that Honda / Acura has already published about these transmissions.
When I took my project on, I didn't pursue it for the purpose of keeping Hondas on the road. I chose to pursue it because I was depressed and I needed something to work on to escape from the crap that was going on in my personal life at the time. During that time, it was an opportunity that presented itself.
Most of the active transmission builders on Instagram focus on transmissions for vehicles that people are okay with spending money on. Older Hondas. B series. K series.
Those vehicles do not require subframes to be removed to swap a transmission. Pulling a transmission off of those vehicles entails mostly removing axles, mounts, cables/linkage. A scissor jack with blocks of wood under the oil pan is usually sufficient holding those engines up.
montero65 (08-02-2024)
#58
Lastly, with the EPA's push for increased miles per gallon and reduced emissions it's no surprise that evs, cvts and double digit speed auto trans are steadily taking over. Which in turn reduces # of manual transmissions in need of service and less techs with hands on experience.
Question: Is this foreshadowing what could become a lost art? #save the manuals
NerdO_TL
02-01-2016 05:58 AM
