Front Rotors.. (Brembo)
Old Sep 24, 2010 | 06:20 PM
ABP_04TL's Avatar
6-SPEED LOVER
So ive had these roughly for around 2 yrs already... just curious to why this is happening to my rotors that thick black line? Please ur help is gladly appreciated. Get in here IHC lol
These are R1Concept rotors
Old Sep 24, 2010 | 10:07 PM
VQPower37's Avatar
funny thing is i have r1 concept rotors, and mine are doing the same thing except a little bit lower on the rotor closer to the hub
Old Sep 24, 2010 | 11:44 PM
eg5's Avatar
eg5
user title goes here
are you using oem pads?
after reading the other post , it seems this might be some sort of wear indicator for the rotors? i.e.visual indicator
Old Sep 25, 2010 | 09:31 AM
Turbonut's Avatar
Take a look at the pad in that area, anything unusual?
Old Sep 25, 2010 | 09:47 AM
nfnsquared's Avatar
I doubt it. The slots are supposed to be the wear indicators.
Old Sep 25, 2010 | 04:44 PM
ABP_04TL's Avatar
6-SPEED LOVER
I'm usin EBC Green pads... I will have to remove the pads and check them out cuz this is strange
Old Sep 26, 2010 | 12:30 AM
nokiaboy808's Avatar
06 6spd TL BAGGED
kind of looks like your brake pads ain't touching that area
Old Sep 26, 2010 | 06:48 AM
Turbonut's Avatar
Although not pertinent to the OP question, thought I'd reply just for future reference, as the rotor thickness wear limit is very small, one wouldn't be able to detect that threshold by viewing the slotted area. As an example, the front M/T rotor when new is .98" and minimal allowable thickness is .91", so as one can see, once the rotor wears .07" or .035" on each side, the rotor is to be discarded. For those that are interested, the front A/T new 1.10", minimum 1.02", rear new .354", .30" minimum.
This is one reason why cutting the rotors are frowned upon as most shops will return a cut rotor that is actually under the service limit. They don’t mic the rotor to see if the limit has been breached, just cut and return. Most owners don't care as they are saving money by cutting the rotors as compared to new units. I consider rotors as throw away items, in most circumstances, just replace with new.
Old Sep 26, 2010 | 07:13 AM
nfnsquared's Avatar
Originally Posted by Turbonut
Although not pertinent to the OP question, thought I'd reply just for future reference, as the rotor thickness wear limit is very small, one wouldn't be able to detect that threshold by viewing the slotted area....
For future reference, please go and read up on the R1 rotors. The slots are indeed used as a wear reference:
Exclusive DIAMOND SLOTS; with R1 Concepts state-of-the-art Technology
* Triangular end points
* Provides for a smooth contact
* Eliminates brake debris at the end of slots
* Indicator of rotor wear
http://stores.ebay.com/R1Concepts/Brake-Rotors.html
Old Sep 26, 2010 | 08:04 AM
Turbonut's Avatar
I'll repeat, the slots are not utilized as a wear indicators. They state that the small triangular tips at the slot end is a good indicator of rotor wear, but they do not state that it is the factory service limit as designated by each OE manufacturer as it's just generic.
Old Sep 26, 2010 | 08:19 AM
nfnsquared's Avatar
I'll repeat. The R1 concepts use the slots as a unique built-in wear indicator, therefore my statement stands that it's unlikely that the black stripe is a wear indicator. I'm not aware of any other rotors that utilize this form of wear indicator nor did I make any statement as to the accuracy or specificity of this advertised R1 Concept wear indicator.
Lucrativesoldier
Sep 28, 2015 03:47 PM
Sep 15, 2015 06:44 PM
Sep 14, 2015 10:10 AM
jmoney2001
Sep 11, 2015 12:07 PM
08 NBP TL
Sep 8, 2015 08:49 PM
