Front passenger window wont roll up!
as the title says, the front passenger window wont roll up. It makes a weird clicking sound when i press the button to roll it up or down, i called the dealership and they it would cost $350 to fix
is there a cheaper way to fix this? any help would be nice
I thought you sold your TL's. Anyways.. first culprit is the window channel and seal. Take the door panel off and make sure nothing is hindering it. Second is the regulator / motor. It costs $86 @ acuraoemparts. You can check for continuity at the posts to verify it needs replacement.
Does the window seal bunch up and window come to a stutter before going back down?
maybe an important note.. that window seal is fucked, because the road noise has been bad ever since I got the car. It sounds like the window is cracked a tiny bit when it's all the way up. Can't really tell where the noise is coming from because I'm always driving.
The alignment is off.
It'll take you some time to line it up.. get some shin-etsu grease and line the seal when everything is in order. If you're really fed up, you can take it to the dealership but I can't promise you that they'll play nice.
and thanks for your responses. if I would have read them sooner, it would have saved me $100
There are tons of bad switches on these cars, but never heard of an issue on the window switches. Mostly transistors and sensor related switches.. not too many mechanical switch issues.
rockyboy
08-04-2024 10:35 AM
nuldabz
09-03-2015 05:49 PM
