Front Overhead Light Problem
Old May 14, 2008 | 01:54 PM
waymay1305's Avatar
I'm having a problem with my 04 TL. The front overhead driver's side light comes on intermittently, paticularly when I'm making a turn, which is then followed by a audible ding. What do you think is causing this?
Old May 14, 2008 | 02:15 PM
Will Y.'s Avatar
Registered but harmless
It sounds like the door switch for the lights might be misadjusted/dirty. When the car body shifts/frame twists, the switch thinks you opened the car door (light goes on) with the key in the ignition ("ding" tone).
A couple of threads mentioned this before. Try cleaning the contact points and turning that door switch in its housing to see if that corrects the problem.
Old May 14, 2008 | 02:17 PM
Tripnbeats's Avatar
yea the latch on the door jam needs adjustment. in more so that it holds the door panel snug to the button
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
darknite123
Integra
Aug 30, 2015 03:00 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
