Front Hub problem
Old Mar 9, 2009 | 09:32 PM
sdm100's Avatar
3rd Gear
Angry Front Hub problem
2007 TL was making road noise after installing 4 new Goodyear F1 All seasons. Went back to Goodyear they stated alignment was not done right replaced 2 tires after 10K miles. Still noise from front Goodyear bites bullet gives me $800 to go back to OEM Michelins, driving home still with noise from front. Friend (mechanic) states most likely Front wheel hub problem Have 3 hr labor quote and $120 in parts. SHould I go with dealer or independent and should I replace both front hubs? Never had to do this on any previous TL and have only 60K highway miles. Not happy 2 tire dealers couldnt figure this out and ended up with $$$ in tire costs.
Old Mar 10, 2009 | 03:48 PM
BoxOn20s's Avatar
It is more than likely the bearings and not the hubs unless the bearings somehow damaged the hub. The bearing will have to be pressed into the knuckle. Usually if you have a bearing problems, the noise will change or shift when going into a turn. If it is the bearings you should be able to get this covered under warranty assuming you havent exceeded the mileage on your 07
Old Mar 10, 2009 | 04:09 PM
erick3's Avatar
speaking of a front hub problem...i just recently had mine replaced. do you need an alignment after? it IS suspension work, right?
Old Mar 10, 2009 | 07:14 PM
Trew's Avatar
Does the noise get worse/better if you turn the wheel left and right as you drive down the road? If this is the case, then your bearings are bad.
As far as the alignment goes... a bad alignment would never cause any kind of noise or shaking.
Old Mar 11, 2009 | 12:51 PM
Tripnbeats's Avatar
yea you would know if the bearing is shot....def try the things trew said...the bearing runs like 40$ and installs like 200 for it....u need to take a lot of shit apart.
Old Mar 11, 2009 | 08:46 PM
sdm100's Avatar
3rd Gear
Yes it is the bearing and yes the car is out of warranty. Am going to change both front bearings cost about $650
Old Mar 12, 2009 | 08:59 AM
Tripnbeats's Avatar
no way ....sdm r u changing the knuckle too???? id get the bearings and go to an independant shop thats got good reviews..... it doesnt take more than an hour to do each side
foxriderar77
Nov 19, 2020 10:17 AM
obert
Nov 14, 2015 09:59 PM
brandnewcolony
Sep 12, 2015 10:39 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
08 NBP TL
Sep 8, 2015 08:49 PM
