Front defrost not blowing
Old Jul 15, 2025 | 03:44 PM
algonquinloon's Avatar
My defrost has been failing over time.. instead of blowing from below the windshield it now blows strong out the two center vents above the display screen only. Tried a search and little came up. Any ideas please? Thank you.
Old Jul 15, 2025 | 08:29 PM
csmeance's Avatar
your mode selection motor is bad and needs to be replaced. What year TL?
It changes the mode from front vents to dash, or to the the floor vents like for heat.
Old Jul 18, 2025 | 11:37 AM
Thank you for the response! 2008.. Been a busy week. Is that motor behind the glovebox? I also read that possibly lubricating it may help.. yes/no?
Old Jul 18, 2025 | 01:36 PM
csmeance's Avatar
lubricating/cleaning can help but that's not going to be a long term fix if the contacts/gear is worn out. It sounds like you need a new mode control motor:
https://acurazine.com/forums/2g-tl-p...orking-975060/
look at the thread above and it'll clarify.
I'm not sure if it's the driver side that controls the defroster but I can't find much info on it. Pretty sure it's above the gas pedal on the 3G TL also.
Old Jul 18, 2025 | 01:57 PM
Thanks again.. looks like it's the driver's side motor.. I've had so little go wrong with this car..
Gregory Kozlowski
3G RDX (2019+)
May 26, 2020 07:12 AM
midlothian
Jan 6, 2012 12:29 AM
greg808
1G RDX (2007-2012)
31
Jan 27, 2009 11:06 PM
chas22
Oct 14, 2004 10:04 AM
aznxtallxboy
Jun 18, 2004 05:26 PM
