Fog lights don't come on
Last night I turned on the foglight switch and, neither one of the fogs came on.
I just checked the fuse under the hood, looks good.
My car doesn't have the panel under the dash but I found this pic of the fuses under the dash
#3 says DRL, is that also fog?
Stay Out Of the Left Lane
According to this thread the relay is under the hood?
https://acurazine.com/forums/3g-tl-2004-2008-93/g-029-diy-independent-fog-lights-stock-switch-772633/
It's not your fault (or being a noob), I posted this too quickly. There are two boxes under the hood. The smaller one closer to the the passenger side is called "Multi Relay" box and the larger once closer to the driver side is called "Under-Hood Fuse/Relay" box.
In the "Multi Relay" box there are two relays. According to what I see the one on the left (closer to the passenger side) controls the fog / DRL lights.
In the "Under-Hood Fuse/Relay" box Fuse #10 works with the Fog Lights relay, Fog Lights.
Hopefully this is more clear and makes more sense.
I checked the fuse in this picture here, the one in front of the intake arm bend
There is a box to the right of that, I think that is the other box you are referring to?
In the other thread, he also located the "fog light relay"
which looks like this
That's not what I want right?
When I took it out there as a loose piece inside. I replaced it with another relay in the car and it works. (see my bzzzzt thread)
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
