Fog light problem
Old Mar 6, 2014 | 08:56 PM
Jriddle8's Avatar
Fog light problem
So I recently upgraded my drls to led, put a harness etc on it. just last week I went to the dealership and got my oil changed. but recently about the same time that I got the oil change
my fog lights have been acting up. I start the car but the fogs won't turn on until I drive a bit. even so only my driver side turns on and after a while the passenger side would turn on.
my fog lights are hid, also with a harness. usually to turn on both fogs I would have to flip the fog switch off and on or else just the driver side would turn on.
Now would this be a battery problem? or just a bad fog light connection. The weather here is also been really cold the past week -20 to -48.
Old Mar 6, 2014 | 09:01 PM
1black_seven's Avatar
Slot Machine Lubricator
Could be an issue with the harness.
VLEDS sells plug and play LED fogs. I've never understood why there needs to be a harness for foglights
Old Mar 7, 2014 | 10:00 AM
Vlad_Type_S's Avatar
Registered Bike Offender
HID Fogs eh? Did you install them yourself? How are they wired up?
Old Mar 7, 2014 | 10:02 AM
the delay upon turning them on sounds like an electrical problem associated with either the ballast or the wiring.
recheck your work.
Old Mar 7, 2014 | 12:00 PM
Jriddle8's Avatar
Yes I installed them myself. used a relay harness. I've had them on for 4 months or so now so they worked quite well before hand only thing was that I had to flip the fog switch to make them both work. But now it's acting funny.
Old Mar 7, 2014 | 01:16 PM
bp_spets's Avatar
If it's been that cold, its possible its too cold for the ballasts or ignitors to light up the bulbs.
Old Mar 8, 2014 | 03:37 PM
Jriddle8's Avatar
I solved this problem, it was the ground wire. The bolt in which the ground was attached to was not properly tightened. It mustve unloosened itself when i did my drls. Thanks anyways guys
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
