Fog light problem
Fog light problem
So I recently upgraded my drls to led, put a harness etc on it. just last week I went to the dealership and got my oil changed. but recently about the same time that I got the oil change
my fog lights have been acting up. I start the car but the fogs won't turn on until I drive a bit. even so only my driver side turns on and after a while the passenger side would turn on.
my fog lights are hid, also with a harness. usually to turn on both fogs I would have to flip the fog switch off and on or else just the driver side would turn on.
Now would this be a battery problem? or just a bad fog light connection. The weather here is also been really cold the past week -20 to -48.
Yes I installed them myself. used a relay harness. I've had them on for 4 months or so now so they worked quite well before hand only thing was that I had to flip the fog switch to make them both work. But now it's acting funny.
I solved this problem, it was the ground wire. The bolt in which the ground was attached to was not properly tightened. It mustve unloosened itself when i did my drls. Thanks anyways guys
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
