Fog light malfunction
Old Oct 9, 2013 | 02:16 PM
S41N7's Avatar
I removed the intake resonator on my 07 and now the driver's side fog lamp wont activate. I tried the bulb on the passenger side and it worked just fine.
Are there multiple fuses for each side or did I manage to damage the harness during the res removal?
Old Oct 9, 2013 | 03:03 PM
Nick216's Avatar
The Boss
Broken bulb, damaged wire, connector on backwards? Not even sure if the oem connector can be backwards, i know my hids can though.
Old Oct 9, 2013 | 03:13 PM
story.customz's Avatar
Just 1 fuse for both. If your passenger side is lighting up, then you damaged the harness
Old Oct 9, 2013 | 03:26 PM
Nick216's Avatar
The Boss
What did you do? like pull the bumper with the wires still connected?
Old Oct 9, 2013 | 04:41 PM
S41N7's Avatar
It has to be the wire, I didn't pull the bumper, though there could've been stress to it during the initial removal.
I will check the connections and see if there are any obviously loose wires. What should I do in that situation? Is it a matter of reseating the wire and soldering or am I gonna have to replace it?
Old Oct 10, 2013 | 12:39 AM
paperboy42190's Avatar
you're asking us how to fix a wire when you arent even sure which part is damaged lol.
honestly though oem harnesses are pretty strong you have to pull really hard to damage it. check with a multimeter first if its getting any power.
Old Oct 10, 2013 | 08:53 AM
Project_CLean's Avatar
MMkay.
Shit, make sure it's plugged in before you get to deep into it.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
