Sidemarker flashing
Old Jul 24, 2012 | 02:25 PM
Storm's Avatar
Sidemarker flashing
Recently on my 06 TL the front passenger side side marker starting flashing really fast, what could be the issue? I don't want to spend $40 on a new side marker when the issue is probably some else. Thanks in advance for any help.
Old Jul 24, 2012 | 02:27 PM
SharksBreath's Avatar
BANNED
your side marker is blinking fast? or your turn signal?
Old Jul 24, 2012 | 02:31 PM
Storm's Avatar
Side marker not the turn signal.
Old Jul 24, 2012 | 02:33 PM
BANNED
i assume you have stock OEM sidemarkers? check fuses under the hood/steering wheel area. if it comes down to it, pop off the sidemarker and make sure its connected properly.
Old Jul 24, 2012 | 02:54 PM
Storm's Avatar
Yes, they are stock. I dont think its the fuse if it is wouldn't it affect both side markers??
Old Jul 24, 2012 | 04:27 PM
ZOMGVTEK's Avatar
Is the flashing consistent, intermittent, or random?
Old Jul 24, 2012 | 05:25 PM
Storm's Avatar
Good question, its Random.
Old Jul 24, 2012 | 05:52 PM
ZOMGVTEK's Avatar
I would replace the side marker.
You could pull the unit and measure the voltage at the light. This could be tricky to do with relatively rapid transients and a cheap meter, but a small halogen bulb or scope should sort it out.
It's probably a bad bond wire on an LED die in the light itself.
Old Aug 7, 2012 | 06:53 PM
Storm's Avatar
replaced sidemarker issue resolved. Thanks guys.!!
Old Sep 14, 2013 | 09:09 AM
prdude12's Avatar
Bringing this back from the dead. I'm having the same issue. Did you replace the entire side marker or just the light in there?
Old Sep 14, 2013 | 11:11 AM
Side marker is a pcb board with LEDs soldered on it so it'll have to be the whole thing unless you feel like troubleshooting the individual components.
Old Sep 14, 2013 | 05:28 PM
paperboy42190's Avatar
I have a great DIY on replacing the LEDs inside the sidemarker here on acurazine....look it up
Old Oct 10, 2013 | 01:25 PM
mle724's Avatar
The side marker on the passenger side went out completely 2 weeks ago. Driver side started flickering last night. Am sure if won't be long. Guess it's time to replace them. Anyone recommend a good online site for purchase?
2004 TL, 121K miles - original side marker lights.
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
thegipper
Sep 28, 2015 01:01 PM
ceb
ILX
Sep 27, 2015 10:56 AM
jmaxima03
Sep 27, 2015 10:22 AM
