flush Brake and Power Steering fluids
Old Oct 19, 2008 | 01:46 AM
Rafiton's Avatar
Well I took my TL-S 08 for service for 9k miles. They told the that I should change the The brake fluids the power steering fluids. I think the is very soon and i shouldn't be doing those chages so soon. I had a Jetta 01 and i did thar change like con 30k. Is this needed right know? Have you experience that?
Old Oct 19, 2008 | 02:03 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Don't do it yet. It's too early. Just check the fluids and top-off for now.
Old Oct 19, 2008 | 08:31 AM
01tl4tl's Avatar
after you complain to the service manager- also notify acura 1-800-382-2238 x5
Its one thing to take care of a car on schedule... and another to just make stuff up!
Reading the owner manual will answer all
Brake fluid starting at year 3 and then every year forever
If severe weather area- start changing brake fluid after 1 year
PS fluid- every 3 years is good
Old Oct 19, 2008 | 12:32 PM
Will Y.'s Avatar
Registered but harmless
That's insane (unless the fluids are contaminated, in which case the warranty should take care of it).
01tl4tl missed one last step in his post above: then never go to that dealer again.
Old Oct 19, 2008 | 01:55 PM
dechlin's Avatar
Ive seen it recommended every 2 years
Old Oct 20, 2008 | 02:50 PM
RACINGHART03's Avatar
I think its a little early for those two fluids to need service. Sure you didnt misunderstand them? If they were pitching a B service to you than they would have mentioned those fluids to you but not asked you for any additional money.
Old Oct 20, 2008 | 03:24 PM
csmeance's Avatar
Brake fluid should be changed after the 3 years the first time, then every year following. PS should be changed when it gets dirty.
Old Oct 20, 2008 | 03:58 PM
01tl4tl's Avatar
whats the owner book got to say about it?
It never hurts to start changing brake fluid after the first year, or two- but definetly by year 3. see: hygroscopic and you will understand
Easy DIY project or brake shop can do it fine.
PS fluid 60k miles, early if you smell it and not so good anymore~
thats just my suggestion based on gen2- see your owner book
many of us fit the severe use description without even racing the car
Old Oct 20, 2008 | 04:02 PM
01tl4tl's Avatar
thanks for the catch will~
I gues if I am going to lead someone step by step to the door,
it needs to be explained that the door has already hit them in the ---
and not to do biz at that dealer anymore
Go meet the staff at other dealers- for any warranty work and oil changes if competative priced
Find a private small import shop for basics or change your own oil
Old Oct 20, 2008 | 04:15 PM
erick3's Avatar
i thought acura recommended that the ps fluid NOT be flushed?
Old Oct 20, 2008 | 08:17 PM
240sx acura tech's Avatar
acura master tech
at 9k thats a little early. unless the brake fluid is black. now the power steering should be done at 15 k if needed.
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
asahrts
Sep 4, 2015 05:55 PM
