First and Second Gear Problem
9th Gear
Today I was leaving a friends neighborhood, taking a right turn onto a main road that is somewhat of a blind turn. I couldn't see anyone when I was at the stop sign but as I pulled out to make the turn I saw a car pretty close so I gunned it in first gear (I have a manual transmission) - red line came up pretty quick and I'm pretty sure I dipped into the ~7500 rpm range. When I came to a stop at the next light, I could not get the shifter into first or second gear and it wouldn't even move over to the left side of neutral. The problem lasted for about 15 minutes with me starting in 3rd gear from stops but after those 15 minutes I was able to put it back into 1st and 2nd gear. I'm sure it was caused by the red line run but could someone help explain to me what exactly happened/caused it and do I have anything to worry about for the future?
Thanks a bunch.
Thanks a bunch.
Registered Member
To my knowledge, you're the first owner who has ever reported anything like this. Engine speed should not have an affect on shifter positioning so this one stumps me. Did you drive all the way to the next light in first gear after having got on it from the stop sign?
Registered Member
When you accelerated hard in first, did you shift really hard and with a lot of force into second?
One thing some folks on this site have reported is that after winding the engine up hard, to high RPM's, the clutch pedal becomes quite stiff and they have to pump it several times before it loosens back up. You are not reporting this, but did this happen with your car?
I have to step out for a while so it might be a little bit before I can get back with this. Your problem is interesting.
Registered Member
To the OP;
Can you delve into a little more detail with this? One other question. To your best impression, does everything seem to be acting normally now? Have you tried to duplicate the problem (I know... I'd be very reluctant to do this one myself).
9th Gear
Thanks for all the input so far. No, my clutch pedal was not stiff at all. I drove the car all day today with no problems - everything seems to be working fine. And yes, I am pretty hesitant to try and recreate the problem haha. As far as the hard shift into second, I guess I could have made a hard shift, once I got pretty high up into the rpm's I shifted pretty quick. You might be onto something there.
Registered Member
Bringing old thread back lol. Were you able to solve this issue? My type s 6spd has been very difficult to get into 1st, 2nd, and reverse since a few weeks ago, and sometimes I have to take off in 3rd from dead stop. It sounds exactly like the issue you described except I don't push my car and always kept rpm below 4k before shifting. I have changed the trans fluid with GM Synchromesh and it helped a tiny bit and problem still exists about 50% of the time....
Originally Posted by CasuallyHung;[url=tel:16853489
16853489[/url]]Bringing old thread back lol. Were you able to solve this issue? My type s 6spd has been very difficult to get into 1st, 2nd, and reverse since a few weeks ago, and sometimes I have to take off in 3rd from dead stop. It sounds exactly like the issue you described except I don't push my car and always kept rpm below 4k before shifting. I have changed the trans fluid with GM Synchromesh and it helped a tiny bit and problem still exists about 50% of the time....
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
