Finally the answers to fix Tranny problems? AND WARRANTY
5th Gear
Hey guys wasnt to sure where to post this but ya here are my questions for the tranny problems and general question:
1. How to fix the transmission shudderon an AUTOMATIC 2004 TL (car seems to like shakes when it shifts) as it shifts notice it when light on the acceleration around 1500 rpms? (include part numbers please)
2.I am out of warrenty is it possible to get extended warrenty at 59000 miles car was imported from US.
You have 59K on your TL so more than likely it's due for a transmission fluid change, however the interval appears to be way to long, its more like every 30K. Also when is the transmission shifting roughly, from first to second when accelerating slowly, or from 3rd to 4th?
Here are some basic things that can provide insight:
1. The transmission will shift a bit roughly when cold in the morning and when you accelerate very slowly. Also sometimes it will shift rough when you are going up or down any road with an incline, such as a hill or even an overpass.
Check your transmission fluid, if it's brown you'll be in a bit of trouble, if it's pinkish red you have a few things to look into. More than likely it's brown and the way to fix it will be a little more involved:
Replace 3 quarts of the fluid (all that will drain) and put in 3 new quarts of Honda Z1 transmission fluid. Also you will need to replace the pressure switches on the transmission.
You can't buy the acura warranty anymore, however you can buy a 3rd Party one. Call up your local dealer and see which ones they usually sell with used cars and which they prefer.
5th Gear
Yes those are the symptoms my tl has but it does it even when its warmed up, and it seems like its shakes when shifting from 2nd to 3rd and 3rd to 4th what are the part numbers for the parts that are needed to be changed?? i am planning on buying all the parts and getting my mechanic to install everything.
And what are the instructions to do the 3x3 transmission flush (Clear details please)
List of parts and there numbers for sensor changes with PRICE if possible please.
THANKS IN ADVANCE.
I Really appreciate the help guys. Just wanna start joining the car and stop worrying about something going wrong with it.
THANKS IN ADVANCE.
I am doing a 3x3 and replacing 3rd and 4th sensors as soon as the parts come in. I am worried if using my car in the mean time could cause permanent damage. Any sugestions?
I could also do the 3x3 next weekend and do the sensors when they come in, which should be the weekend after. what you guys think?
Peace,
Rolan
definitely time to change rolan.. waiting a week wont hurt but do it sooner than later. Change your ATF filter as well.
5th Gear
I have a 04 TL 5AT I am going to get these parts tomrrow to do the switch change and 3x3 tranny flush
Can i get the latest update on what parts i need ive read bunch of forums it its giving me different part numbers..
(SO please all the part numbers for a 2004 acura tl PLEASE)
you are going to need to change your fluid as it's light brown and no longer redish pink.
If this bad for the color of my transmission fluid?
Peace,
Rolan
Peace,
Rolan
I just had the fluid flushed on mine by the dealer, one change I believe, and it is smooth when warm, but when cold it shifts a bit rough other than that it seems fine. 32k miles I think that is just a normal trait when it's cold. My 06 TL did similar when cold.
HeloDown
09-08-2015 06:51 PM
