Fading Paint
Old Jun 5, 2014 | 04:32 PM
jpm3071's Avatar
Fading Paint
Hey Guys,
I removed the underline felt material from my hood and regretfully threw it away. Ive noticed the hood is starting to fade slightly and I was thinking of ways to prevent it from getting worse besides going to the dealership and buying a new liner.
I have the cowl mod done but was thinking of putting a slight elevation on the rear of the hood just to add some extra ventilation. Do you think this would alleviate the issue? Any suggestions?
Old Jun 5, 2014 | 05:56 PM
csmeance's Avatar
Paint on hood, roof and trunk lid will fade faster than any other area's of the car because of it's exposure to sunlight! I doubt that the heat is causing the fading compared to just the age of the car and whatnot.
All your car needs is a simple detailing! Polishing will remove the top layer of oxidized paint which causes the "faded" look. Always start with the least aggressive polish/compound and then work your way up to avoid using too harsh of a product! After all the paint on our cars is as thin as a sheet of paper!
Check out the wax and wax section!
Old Jun 5, 2014 | 06:18 PM
^what he said.
it has nothing to do with the engine heat but more so from UV rays.
remember, waxing is important. keeping it protected from sun light will prolong the life of the paint
Old Jun 5, 2014 | 08:41 PM
Jesstzn's Avatar
Unless your roof and trunk are faded too or treated differently.. Then it kind of narrows it down doesn't it .. Added internal heat.
Old Jun 5, 2014 | 09:31 PM
^psh, the underhood blanket is a fire suppressor.
it comes down to taking care of the paint.
Old Jun 5, 2014 | 09:40 PM
Jesstzn's Avatar
I'm sure your right... OP .. Is the tops of your fenders , roof and trunk faded too?.. Or just the hood?
Old Jun 5, 2014 | 10:19 PM
DeathMetal's Avatar
Fearless DIY Guy
I've had my fire blanket removed for over two years now with 0 ill-effect observed on the paint. The blanket was removed due to the additional of an MDX mainfold spacer.
...I also use a QD weekly and use a machine application of paint correctors, clay bar, and synthetic wax bi annually. Seriously, it comes down to taking care of the paint.
If you need a replacement, you could always buy mine
Old Jun 5, 2014 | 10:39 PM
Jesstzn's Avatar
That theory is correct... IF the fading is all over .. If just the hood then its another .. I'm not blowing smoke.. I'm well versed on paint reaction to UV and other issues.
Old Jun 6, 2014 | 09:29 AM
jpm3071's Avatar
I noticed it first on the hood but now that I took a closer looks its beginning on the trunk lid as well. Thanks fellas!
Old Jun 6, 2014 | 10:34 PM
Jesstzn's Avatar
If its more than just the hood the the pad isn't the issue. Your not in intense sun country but if your car hasn't been protected you "could"have fading . When is the last time you waxed the car? Do you do it regularly?
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
spoiler900
Sep 23, 2015 04:41 PM
