Every corner i turn onto the door open chime sounds..
Yep, you heard it right. I turn a corner and the chime will sound and the lights will go on, as if a door is open...What the heck could it be?
The DVD-A Script Guy
Did it start after any maintenance or any really wet drives? I'm thinking a wire could have been dislodged if you had work done or water got into somewhere and it moves when you turn.
on the pillar on the outside of the door, about 1 foot above the bottom of the door sill should be a black ribbed rubber button (about 1/2 inch sticking out) looking thing that you can press in. This is the door open/close sensor, make sure it's not bent on that side.
adjust the door striker inward. give it a couple whacks with a hammer. this will allow the door to close closer and keep the door switch closed. ive seen this a few times and this fix has worked every time
rockyboy
08-04-2024 10:35 AM
