Error codes
Old Jul 4, 2019 | 12:54 PM
Acurate_'s Avatar
Error codes
So while driving I noticed in the top right corner of the Navi screen a messages icon. When I clicked on it, it showed all of the errors in the car which I've attached. My issue is , the car drives well to my knowledge. It shifts smooth , no knocking sounds or weird noises. Only thing I can say is when I put the car into D it vibrates slightly, but it doesn't affect the way that the car drives. I'll try and put a video up when I get a chance. Any help would be appreciated
Old Jul 4, 2019 | 01:04 PM
Acurate_'s Avatar
Also I believe I read somewhere that their was a known issue causing the "tighten fuel cap" error which I keep getting. Is their a way to fix this?
Old Jul 4, 2019 | 01:05 PM
if there's an option to clear those messages, clear them.
replace the evap purge valve to fix the gas cap
Old Jul 4, 2019 | 08:48 PM
Will Y.'s Avatar
Registered but harmless
Originally Posted by Acurate_
So while driving I noticed in the top right corner of the Navi screen a messages icon. When I clicked on it, it showed all of the errors in the car which I've attached. My issue is , the car drives well to my knowledge...
Also check your battery output while on and off. If the battery is more than 3 years old, just replace it, then clear the codes per justn above.
The TL is sensitive to dying batteries and can toss out numerous unrelated error codes as a result.
Nicknackzz13
Aug 3, 2018 11:04 AM
woowoo
May 23, 2011 10:03 PM
synth19
Feb 6, 2011 10:49 AM
RKeatF1
Nov 20, 2007 06:56 AM
Chauncey
May 31, 2005 07:58 PM
