Error Code P2422
Error Code P2422
Has anyone encountered this error code P2422??
I filled up at BP, right after went strong for one block with VSA off...(a 335 was being a jackass)
An hour later I got the malfunction light.. The car drives fine. I've disconnected the battery. Resetted the code. Drove for 15 miles, and the light is back on.
Ideas???
Ideas???
Thanks, I know what the code reads... Just trying to understand how can a 2008 have EVAP valve malfunction... Or what is the solution...
Not happy at the moment...
this could have happened due to a loose gas cap...
As per manual, I'm suppose to get a Tighten Fuel Cap on my MID along with a pcode... And I after I pulled this code, I don't know, it seems it's something else.
But I'll give it a few days... Thanks guys.
Bump...
Car drives fine, the malfunction light is still shining bright. We'll raise the car tomorrow I guess and see if anything is loose by the canister...
Registered User
you ever find anything that caused the issue? i'm getting the same code, and after 50 miles of driving the code comes back after clearing it.
i removed the canister, cleaned the tubes out, and tested the canister valve which works fine.
I have the same p2422. Trying to order a new valve but there is a lot of confusion out there about the valves on the EVAP. I found some diagrams that helped me understand what I needed to order but still looking for actual part #'s.
http://www..com/forums/content/manua...P%20System.pdf
also
http://parts.sonsacura.com/showAssem...ssembly=268594
also
Registered User
the valve is part number 2 in that diagram on
http://parts.sonsacura.com/images/pa...ize/396393.png
problem that honda/acura won't tell anyone is that most of the time it's spider webs that case the issue, and all you need to do is blast the hose numbered 14 with air.
Jamus22
06-11-2023 10:08 AM
