Error Code P2422
Old Jun 7, 2009 | 05:17 PM
TeknoKing's Avatar
Error Code P2422
Has anyone encountered this error code P2422??
I filled up at BP, right after went strong for one block with VSA off...(a 335 was being a jackass)
An hour later I got the malfunction light.. The car drives fine. I've disconnected the battery. Resetted the code. Drove for 15 miles, and the light is back on.
Ideas???
Old Jun 7, 2009 | 05:26 PM
paliknight's Avatar
i hope this has nothing to do with BP. i always fill up there. good luck with the code though. i hope its nothing serious.
Old Jun 7, 2009 | 06:18 PM
woot427's Avatar
Evaporative Emission (EVAP) System Vent Shut Valve Close Malfunction is what the code correlates to.
Old Jun 7, 2009 | 06:24 PM
woot427's Avatar
Also, make sure your gas cap is on tight enough. Take it off and make sure it clicks at least three of four times. Wait a few days to see if that resolves the issue
Old Jun 7, 2009 | 06:31 PM
woot427's Avatar
damn 5 minute edit rule -- I wanted my previous statement makes sense since you said this occured after getting gas.
hopefully it resolves the issue. let us know!
Old Jun 7, 2009 | 08:48 PM
TeknoKing's Avatar
Thanks, I know what the code reads... Just trying to understand how can a 2008 have EVAP valve malfunction... Or what is the solution...
Not happy at the moment...
Old Jun 7, 2009 | 10:44 PM
csmeance's Avatar
this could have happened due to a loose gas cap...
Old Jun 7, 2009 | 10:47 PM
woot427's Avatar
yes, same thing i said above as well. it makes sense since it happened after you got gas. take it off, give it a few clicks to make sure its tighten, and then see if it disappears within a few days
if not, lookin like a trip to the dealership.
Old Jun 8, 2009 | 12:36 AM
ssmtl2nv's Avatar
2009 g37s 6mt
Igor, try and tighten the gas cap first and see what happens in a few days bro.
Old Jun 8, 2009 | 06:15 AM
TeknoKing's Avatar
As per manual, I'm suppose to get a Tighten Fuel Cap on my MID along with a pcode... And I after I pulled this code, I don't know, it seems it's something else.
But I'll give it a few days... Thanks guys.
Old Jun 9, 2009 | 08:29 AM
TeknoKing's Avatar
Bump...
Car drives fine, the malfunction light is still shining bright. We'll raise the car tomorrow I guess and see if anything is loose by the canister...
Old Jun 9, 2009 | 10:24 AM
Tripnbeats's Avatar
it actually correlates to the canister valve being stuck closed i think, or open. whichever one its not good.
Old Oct 3, 2010 | 07:13 PM
rbf351's Avatar
Registered User
Originally Posted by TeknoKing
Bump...
you ever find anything that caused the issue? i'm getting the same code, and after 50 miles of driving the code comes back after clearing it.
i removed the canister, cleaned the tubes out, and tested the canister valve which works fine.
Old Oct 16, 2010 | 09:26 PM
Rounder's Avatar
2008 Acura TL
bump. how long will this take the dealer to fix?
Old Aug 5, 2011 | 01:13 PM
BluesMan11's Avatar
I have the same p2422. Trying to order a new valve but there is a lot of confusion out there about the valves on the EVAP. I found some diagrams that helped me understand what I needed to order but still looking for actual part #'s.
http://www..com/forums/content/manua...P%20System.pdf
also
http://parts.sonsacura.com/showAssem...ssembly=268594
Old Aug 5, 2011 | 01:17 PM
rbf351's Avatar
Registered User
the valve is part number 2 in that diagram on
http://parts.sonsacura.com/images/pa...ize/396393.png
problem that honda/acura won't tell anyone is that most of the time it's spider webs that case the issue, and all you need to do is blast the hose numbered 14 with air.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
