Engine/Transmission Roughness
Old 03-06-2016, 04:23 PM
Carsmovies's Avatar
I have a 06 TL Auto with 30,000km. I find that when idling and when the engine is running at about 1500RPM there's a bit of a roughness. It's most pronounced when cruising in 5th gear at 1500RPM. I'm using Amsoil signature 5W20, have changed the transmission oil with DW-1 several times and even changed the spark plugs. It's also pretty rough when the engine is very cold and just started. Is this normal?
Old 03-06-2016, 04:33 PM
Registered Abuser of VTEC
youngTL's Avatar
Motor mounts most likely. Also how does the thing only have 30k on it when it's over 10 years old?
Old 03-06-2016, 04:36 PM
Carsmovies's Avatar
That's what I was thinking. Are they adjustable or need to be replaced? I bought last year with only 10,000km. Was from an old man that never really drove it and was never winter driven either. It still smells new inside.
Old 03-06-2016, 04:44 PM
youngTL's Avatar
With that little distance on it, it's not as likely but it's still possible. Rubber degrades over time.
Old 03-06-2016, 04:46 PM
Carsmovies's Avatar
Is there a way to examine the rubber without removing them?
Old 03-06-2016, 09:39 PM
youngTL's Avatar
Not really. You might as well just swap them.
Old 03-07-2016, 12:21 PM
Carsmovies's Avatar
Would you have any idea how much that would be?
