engine ticking when cold
Old Feb 27, 2006 | 01:37 PM
edsonfire's Avatar
05' WDP A-SPEC
i just noticed that my enigine is ticking a bit. real noticable when its cold, not so noticable when its hot but you can still hear it. my car only got 9000 miles on it and i baby it. never even really opened it up unless i was getting on the parkway. anyone else have this problem? what coould it be? i guessing my valves might need adjusted. do you think the warrenty will cover this?
Old Feb 27, 2006 | 05:33 PM
sebounet2005's Avatar
TL 2012 SH-AWD TECH/UMBER
Good luck, i'm fighting with Acura for months now about that. I think it's an heatshield issue, but it's hard for them to understand that the sound is not normal. They said ''we test another TL from another customer and same noise'' Yes i know but the problem touches a lot of TL. The problem is the people that repair cars used to have mofidied 1995s Civic with a big sound system, so they are death and won't know what a good engine sound is.
Old Feb 27, 2006 | 06:07 PM
weedeater's Avatar
I guess I would ask when you hear it.
Hood open?
Inside car?
Outside car?
Matches engine RPM?
At startup, but disappears after it warms up?
One thing I've heard on my other car is a 'ticking' noise from the injectors. But that's usually very quiet. The other ticking noise which would be a bit louder is from a valve. IIRC, valve adjustments are part of the maintenance of this engine. I doubt that it would be covered under warrantee. It's not that hard to do, but it has to be done on a cold motor.
Old Feb 28, 2006 | 06:50 AM
willz822's Avatar
Can you be a little more specific as to what you mean by ticking? Is it more like a vibration or an actual ticking sound? Is it only audible or can you actually feel the ticking through the steering wheel and other parts of the car?
The reason why I'm asking is because I have a similiar issue but it's more like a vibration than an actual ticking sound.
Old Feb 28, 2006 | 12:11 PM
edsonfire's Avatar
05' WDP A-SPEC
the ticking is definatly coming from the engine. ive heard the heat sheild rattling before on another tl and im sure its not that. my guess is that its either the injectors or the valves. the ticking matches the rpm's and can be heard with the hood shut, heard mainly on only one side of the car but can be heard from the other faintly. why does acura have to be so damn difficult with their service and warranty? what are my options if it is the valves or injectors that are ticking?
Old Mar 3, 2006 | 02:16 AM
JS + XES's Avatar
I drive a Subata.
Okay.. I'm not sure we are talking the same thing.. but recently, I've been noticing a vibration whenever I start up my car in cold weather. The car just vibrates ALOT! I don't think it's getting worse or anything, but it's starting to bother me.. Don't know what to do..
Old Mar 3, 2006 | 02:17 AM
JS + XES's Avatar
I drive a Subata.
Hey, I think we have the same problem.. does your car vibrates only when you start the car in cold weather? DOesn't it go away after a couple of minutes of warm-up?
Old Mar 3, 2006 | 07:09 AM
Brettg's Avatar
From the looks of things, the engine does not use lifters, but uses an adjustment for valve lash at the rocker arms. It would be easy to adjust the lash, but the question is why one/some valves would be out of spec so early.
I would not let it pass, since its not normal, and could be a sign of excessive wear on some valve train part, cam, cam follower, valve tip, etc.
I cant think of anything other than the valves that would tick.
Brett
Old Mar 3, 2006 | 08:07 AM
willz822's Avatar
The car still vibrates in warm weather when starting but not as bad. It doesn't completely go away when the car is warmed up. It's still slightly noticeable and I've pretty much gotten used to it.
Old Mar 3, 2006 | 08:20 AM
chfields's Avatar
The warranty should cover any issue you are having with the engine. Take it to the dealer and have them check it out.
Old Mar 3, 2006 | 06:02 PM
special-ed's Avatar
Iro Ridg .308
what's the mileage on the car?
Old Mar 13, 2006 | 11:02 AM
mio's Avatar
mio
Police
acura service= normal
rockyboy
Aug 4, 2024 10:35 AM
BoricuaTL
Apr 8, 2016 01:08 PM
01CLOwner
Oct 9, 2015 01:07 PM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
dlknight
Sep 3, 2015 07:54 PM
