Engine Tick
Old Nov 25, 2018 | 02:45 AM
mayjarjar's Avatar
Acura Member
Engine Tick
Hey guys, I've noticed my 06 TL has some ticking coming from the engine. I'm just wondering if this is a normal noise for an engine with 175k miles on it? If not, does anyone know what it is and how to fix it? I tried doing some research and found some articles stating to do an oil flush and put in a quart of Lucas oil additive with the new oil. I'm not too educated when it comes to oil additives but I'm not a fan of sticking any fluids in the engine other than the prescribed oil. Any help would be appreciated.... below is a link to video I recorded of my car.
https://youtu.be/KzpQPs70vP4
Also, I bought the car about 2 months ago. Previous owner had the spark plugs replaced about 35k miles ago. I just recently had the timing belt and water pump replaced as well. As far as a valave adjustment.... I'm not sure. If I should have a valve adjustment done what are the typical prices to pay for that?
Old Nov 25, 2018 | 10:13 AM
WheelMcCoy's Avatar
Based on the mileage, my first guess would be a valve adjustment. Just to learn what's involved, here's some info from Road & Track:
https://www.roadandtrack.com/car-cul...ve-adjustment/
Repair PAL estimates $300 for the job:
https://repairpal.com/estimator/valve-adjustment-cost
Old Nov 25, 2018 | 01:22 PM
mcmanut's Avatar
The 1st thing to check is the spark plugs and make sure they are good and tight. Especially the #5 cylinder.
Old Nov 25, 2018 | 08:38 PM
Midnight Mystery's Avatar
Null and proud of it
Start with spark plugs and valve adjustment... This is common on TL's...
Old Nov 25, 2018 | 08:40 PM
2006 TL Engine Tick Video
Old Nov 25, 2018 | 08:42 PM
Your link was bad so I reposted it...
My 2008 TL was a lot louder than that, and my tick was a little slower... Best of luck...
Old Nov 26, 2018 | 12:10 AM
mayjarjar's Avatar
Acura Member
Thank you all for the replies and the good insight. I will definitely check the spark plugs and if that doesn't resolve the issue I will try a oil drain and refill. Previous owner said he did it about 1000 miles ago but it never hurts to do it yourself for good measure. Oil looks relatively new and the filter has no dirt or debris on it so I believe that the previous owner was telling the truth.
Old Dec 5, 2018 | 03:38 PM
jisleyjr's Avatar
Sounds normal to me.
InFaMouSLink
Aug 1, 2024 11:44 PM
Jopa
3G RDX (2019+)
173
Apr 11, 2024 06:56 PM
LikeMyTL
Dec 9, 2018 02:07 PM
MATT2816
Nov 25, 2018 07:46 PM
jsurpless
ILX Audio, Bluetooth, Electronics & Navigation
Nov 24, 2018 06:34 PM
