engine temperature gauge reads low
Old 03-26-2010 | 08:53 PM
ilsim1703's Avatar
hi guys~
does anyone knows why temp gauge needle points at low?
i thought it should stays at middle or bit lower than middle.
please help!!!!!
Old 03-26-2010 | 09:07 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Has it always been this way, or did you just buy the car and don't know?
Old 03-27-2010 | 01:32 AM
SpiderX1016's Avatar
x2 and Does the gauge even move?
Check the thermostat.
Old 04-20-2010 | 07:30 PM
ilsim1703's Avatar
Exclamation Help!!! my engine temperature gauge settles low
hi guys~
here is my problem. i got a 08 acura tls, recently, i found my engine temperature gauge points kinda low. so, i went to local dealership and they respond to me that it should be fine due to its in the tl spec range(160F~212F), but the thing is i did have gauge settles at little bit higher than 8th dash on the gauge when i first purchase, now it settles at 6 1/2th dash. can anybody give me a idea why? or did anybody have a simular problem before? help me plz~~~~~
Old 04-20-2010 | 08:31 PM
Adobeman's Avatar
The DVD-A Script Guy
Mine's steady since day one. Not sure I follow about 8th vs 6 1/2. Have you noticed any decrease in fuel economy? You might see that if the car is running way too cool. If the car is running within the spec then it will be a tough battle to have them replace your thermostat under warranty. My guess is your thermostat has drifted. Any mods done?
Old 05-05-2010 | 01:54 PM
ilsim1703's Avatar
thank you for the reply adobeman, i didn't do any modifications. i know it will be very tough to fight about and replace...fuel economy looks no big difference than before...
Old 05-05-2010 | 01:57 PM
ilsim1703's Avatar
it was settled at 8th dash when i first purchase, now it's at 6th 1/2. what's is wrong with my thermostat?
Old 05-13-2010 | 10:41 PM
ilsim1703's Avatar
anybody has any idea?? please help!!!!! T.T
02-25-2020 09:57 AM
OculiAquilae
11-19-2018 02:24 PM
PortlandRL
09-14-2015 12:01 PM
Bahamanurse1
09-10-2015 10:05 PM
Quick Reply: engine temperature gauge reads low
