Engine Temperature Gauge
Old Jan 20, 2015 | 04:46 PM
06TLMatt's Avatar
Unhappy Engine Temperature Gauge
When I turned my 06 TL on this afternoon, the Engine Temperature Gauge stayed all of the way on the bottom , while all of the other gauges shot up. Also, I'm not sure if this is related or not but a couple of times when I have went to start the car, nothing has happened, then after I try again it just starts perfectly. Any idea whats going on or if it is related
Old Jan 20, 2015 | 04:47 PM
06TLMatt's Avatar
When it's not starting, it doesn't turn over or anything, it just doesn't make a noise at all
Old Jan 20, 2015 | 04:58 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
How old is your battery?
Check your battery connections - make sure they are tight and clean.
With an intermittent problem, it may be electrical.
Old Jan 20, 2015 | 05:58 PM
riomp300's Avatar
Try the gauge sweep test
"Hold trip/reset button
Turn headlights on
Turn ignition switch to ON
Within 5 seconds turn the headlights off, then on, then off
WIthin 5 seconds release the trip/reset button, then push it 3 times
The MID will light up and test itself, all dummy lights will flash, and the needles will sweep from min to max to min
Pushing the trip/reset button repeats the test!"
Old Jan 20, 2015 | 06:17 PM
06TLMatt's Avatar
Well it was moving slightly up but just barely so I don't think that the gauge is broken
Old Jan 20, 2015 | 08:58 PM
vietxquangstah's Avatar
Have you tried driving your car for 10+ minutes than checking the temperature gauge?
From your original post it sounds like you're starting your car for the first time of the day and expecting the coolant gauge to move immediately. Your engine coolant has to warm up first
Old Jan 20, 2015 | 09:00 PM
06TLMatt's Avatar
It hadn't been driven for a couple of hours. The temperature gauge not springing up didn't really bother me, it was just in combination with the not starting/turning over that made me kind of suspicious of something.
rockyboy
Aug 4, 2024 10:35 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Sep 21, 2015 08:44 AM
Sep 17, 2015 09:01 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
