Engine Oil after 100 k miles.
Hello there,
Need some advice on engine oil after 100 000 miles. What would you recomend to keep my car in tip top shape? I don't want any engine clicking. Also i'm concerned about Viscosity grades cuz i live in NYC and weather is changing every 2 hours and it could be very cold during the winter time
Any suggestions?
FYI if somebody doesn't what is vicosity here you go :http://www.upmpg.com/tech_articles/motoroil_viscosity
I have run Royal Purple, Mobile 1 and Pennzoil Ultra in 5W-20 variety. These oil threads are well traveled and can be found by using the search function. 5W-30 is also a legit option.
justnspace (08-27-2012)
You don't need to start doing anything special once the odo says 100,000.
Most modern oils are fine, just change it frequently. If you're looking for the ultimate in protection, something like M1 EP 5w20 / 5w30, or Penzoil Ultra are good oils you can generally find locally. Combine that with a good filter and it's about as good as you can do.
If you're really interested in knowing why this stuff matters, consider getting your used oil analyzed by a lab like Blacksone, or hang out on bobistheoilguy forums.
Bruce Banner (08-29-2012)
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
