Engine noise?
Old Feb 21, 2012 | 03:15 PM
micka628's Avatar
Angry Engine noise?
2005 TL 3.2 6speed manual with almost 100,000 on it. Started it up yesterday afternoon and it started making engine noise. Progressively getting worse. No codes have come on, no loss of power, not missing at all. Any thoughts? Oil was a little low but nothing major, and has always been changed regularly.
Old Feb 21, 2012 | 04:34 PM
Turbonut's Avatar
What type of engine noise, rattle, knocking, ticking, squealing, etc?
Old Feb 21, 2012 | 11:30 PM
dz04tl's Avatar
i have an 04 tl with 103k and suddenly in less than a week I noticed the engine sounding noisier i too have no codes... how can i improve this....
Old Feb 22, 2012 | 08:05 AM
TbirdTommy's Avatar
here are some videos on the noise.. let me know what yall think. Im thinking timing belt tensioner? thanks!!
this is at a first startup cold
this is after a short warm and drive
Old Feb 22, 2012 | 11:12 AM
kingkong_dav's Avatar
KingKong_Dav
that sound f**k up. could be bad pulleys on the drive belt or worst, timing belt components, get a lil wd40 and spray it on the belt and pulleys, lightly tho, see if it stops
Old Feb 22, 2012 | 02:00 PM
TbirdTommy's Avatar
well i need to do the timing belt anyways.. i just want to make sure this is what is causing the noise.. thanks!!
Old Feb 22, 2012 | 05:57 PM
TbirdTommy's Avatar
safe to drive?? or is it possible it will shit the bed?
Old Feb 22, 2012 | 06:01 PM
Sotiris's Avatar
2004 Acura TL
Try checking the pulleys, my neighbors TL was making the same noise he changed the pulleys and it seems to be alright now, good luck bro
Old Feb 23, 2012 | 05:38 PM
TbirdTommy's Avatar
its surely coming from the rear head area close to the timing cover.. I talked to my honda stealership they said not to drive it... quoted me $900 to do timing belt work and then i called my acura stealersip and they quoted me $1400! ugh wish i knew that was the problem
Old Feb 25, 2012 | 03:17 AM
handy911's Avatar
Mine has only 50K miles, is it time for timing belt already?
Similar noise on my 06 TL, it's more like this though:
Is it timing belt? Or is it something else? I am not too familar with cars, what are pulleys for?
Old Feb 25, 2012 | 06:21 AM
Turbonut's Avatar
Remove the sepentine belt and start the car briefly to see if there is any noise, if no noise you located the area and it's not the timing belt or components.
Old Feb 25, 2012 | 03:05 PM
handy911's Avatar
thanks. I brought it to my local auto shop (specializing in Acura and Honda), and was told that the engine sounds completely normal. I trust this guy, but went for a second opinion anyways and went to the dealer. First, they said it also sounds normal, but they pointed out that the external belt is kinda worn out. Normally it has to be replaced every 7 years or 90,000 miles. My car is 2006 and has only 53,000 miles. But, the dealership also told me that I need a new power steering pump, bc it's leaking (although I know that it's not, since it has just been recently repaired due to whining noise in the morning), and fluid is full. This is pretty standard way of dealerships trying to make money I guess.
My question is: when do we need to replace the belt really? it looks worn out, but I've never seen any belt that looks "perfect" unless it's new. And I'm in California if it matters.
Old Feb 25, 2012 | 03:17 PM
I hate cars's Avatar
Seriously, stop giving advice, you're going to cost someone a lot of money.
To the OP, it's too quick to be a rod knock or valvetrain. Sounds like it gets worse with heat. I would say a hurt piston or more likely a pulley.
Does it get worse with load or with rpm?
Also, was the AC or defrost on at the time? I'm sure you would hear it cycling but I've heard AC compressors sound like this as well right before they go out. I wouldn't concentrate on this too much, slim to no chance but I thought I would throw it out there.
Old Feb 25, 2012 | 07:33 PM
TbirdTommy's Avatar
having a load on it makes no difference, the noise does increase with rpms as well. I have an acura tech stopping over tomorrow to take a look for me. I really hope its something stupid. Just got our income tax and really don't want to spend it on a new motor.
Thanks for the reply
Old Feb 25, 2012 | 07:41 PM
If having a load on it makes no difference, it's probably nothing to worry about. You could almost rule an internal problem out. Probably a pulley.
Old Feb 25, 2012 | 07:57 PM
Trunk Monkey's Avatar
Coolest A-zine Member
http://www.youtube.com/watch?v=kC4aVjY7p28
My engine sounds just like this.
shit
Old Feb 25, 2012 | 08:38 PM
handy911's Avatar
shit
I might just have to live with this. Since 2 mechanics I saw today told me it was normal. I think changing the exterior belt would not solve this issue. The pulleys seem to be normal and not out of place or something.
Old Feb 26, 2012 | 01:14 AM
I would do what Turbonut says and take the belt off and start it for a few seconds. This will eliminate all pulleys and accessories driven by that belt. What part of the country are you in?
Old Feb 26, 2012 | 11:40 AM
iodprod's Avatar
try reading up my thread about engine noise
https://acurazine.com/forums/3g-tl-problems-fixes-114/engine-ticking-loud-under-3000-rpm-when-cold-helpppp-848337/
maybe this would help.
yours might be the tensioner on the acc belt mine is going also.
look at it carefully is it vibrating when spinning?
Old Feb 26, 2012 | 12:30 PM
TbirdTommy's Avatar
Looks to be the exhaust valves... going to be a few weeks before the work can get some done he is doing the timing belt and valves for $300 not including parts
Old Feb 26, 2012 | 01:09 PM
Exhaust valves are usually quiet and intakes make the noise. Not always but over 50% of the time that's how it is.
I can tell you beyond a doubt, the noise in the video is not exhaust valves. The engine would not idle with that kind of noise if it were exhaust valves and it's the completely wrong sound.
Old Feb 26, 2012 | 02:59 PM
TbirdTommy's Avatar
well im just saying thats what the 10 year service tech from acura said.. guess we'll find out when he does the valves and belt since they need done either way
Old Feb 26, 2012 | 03:34 PM
swoosh's Avatar
takin care of Business in
sub'd
Old Feb 26, 2012 | 06:32 PM
The noise will probably go away when he does the belt since whatever pulley is causing the problem will likely be replaced. Hopefully he gives you back the failed component so we can see.
Old Feb 26, 2012 | 06:57 PM
TbirdTommy's Avatar
trust me as long as its fixed ill be a happy camper. I still think as well that its a auto tensioner taking a shit but the valve need adjusted either way. i do appreciate the help tho
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
