Engine Mount(s) gone bad
Old Dec 6, 2010 | 05:01 PM
zackjackson's Avatar
I have been noticing a pretty loud clunking noise from the front passenger side on the road bumps. After reading some of the post here I thought I would check the passenger side engine mount and of course it was all damaged.
1- How can I check and see if the front and the rear ones are damaged as well without having to remove them first?
2- Should I just replace the passenger side and see if the clunking noise is gone. And if yes, then consider the front and rear mounts to be OK?
3- Where do guys recommend that I should get my parts from? I am sure the dealership is going to charge me 3 arms and a leg!
Old Dec 8, 2010 | 12:14 PM
Anyone willing to help me out on this?
Old Dec 8, 2010 | 12:38 PM
nfnsquared's Avatar
Search is your friend. Found these using "motor mount" as a search term:
https://acurazine.com/forums/3g-tl-problems-fixes-114/replaced-my-motor-mounts-pics-inside-772642/
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/motor-mount-replacement-experience-769734/
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-2006-acura-tl-side-motor-mount-replacement-796676/
Use the Vendor link at the top right of the page to find parts...
Old Dec 9, 2010 | 01:29 PM
GRFAcura's Avatar
3rd Gear
I have a 2004 TL with 103K miles. Just changed the compliance bushings as well as the passenger side and front engine mounts. You probably need the same after 125k miles.
I found that Hondapartsunlimited.com had best prices and delivered quickly For example, front engine mount was $150 at dealer, $115 or so for most online Acura parts sellers, but only $95 at Hondapartsunlimited.com
They report themselves as Showcase Honda in Arizona so they sell official Honda parts.
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
