Engine Mount Diagnosis
Sorry guys, I don't know a whole lot about this, but I do suspect I have a bad mount. Vibration, hesitation on accel, and some odd shifting. A slight rattle sound. Pretty much all the symptoms I had before replacing the passenger side mount. It was great for a week but then came back, so I'm thinking another one went. How can I tell if they are actually bad? From the manual it says to have Acura test the control system, which OK that sucks because in Maine there's only really 1 Acura service, and they absolutely suck. They totally fucked up when they did the 105...left the passenger side mount loose, and it ended up breaking...another screw they left loose for a harness fell out completely....just absolute BS. Anyway, not really the point of the thread. Just looking for a way to determine if another mount is bad.
I've seen people recommend throttling and watching engine movement, which doesn't help me because I have no baseline to compare with. Rubber missing, maybe? I don't see any fluid leaks.
They also did the plugs, so I'm going to get in there and make sure their shitty ass wrenches didn't tighten the plugs enough as well.
Any help would be greatly appreciated. May just drive it to Mass and have the service department there go over it, but I'd rather just get better at doing the work myself.
Thanks in advance.
Thanks in advance.
punkascii (12-19-2013)
I just changed my mounts. My car had 130k miles of hard driving (autocrossing and generally spirited driving).
My car would make terrible noises going over the smallest of bumps. I would have to crawl over speed bumps, and even then it would make *thunk* noises. my mounts had been shot for quite some time, and I let it get worse and worse.
My side mount was in pieces, my front mount was in pieces, but my rear mount was actually alright. It wasn't torn or anything. The rubber looked stressed, but that's about it. In otherwords, I dont think its your rear mount.
When your engine mounts start making noise, you will know it. I mean, even when starting my car, I could literally hear the engine bouncing on the broken mounts.
If you're going to start replacing mounts, id go straight for the side and front (in your case, the front since you already replaced the side).
I just put the car in drive and held the brakes while givingg the engine a little rev. The Engine moves I would have to say a good inch or so up....could be the front after witnessing that. I don't really think it should move that much. Seriously it could be 2 inches! I'll try to post some video.
you can't tell if they're fine just by looking at them, you have to remove them. Acura told me my passenger and front mount was fine, but i noticed excessive motor movement that didn't look right. i took out the mounts and both were shot.
I moved up here and bought a Jeep GC. Brought it to a mechanic to look over before buying. Oh yeah, its great. A week after buying the control arm was F'ed so we brought it to another mechanic...yeah this isn't the original motor. Nice. Would have been nice to know that.
I had a 06 Frontier that was acting like the trany was going. Brought it to a different mechanic. Nope it's spark plugs. I've had bad plugs and wires..I know that feeling. A month later BAM, tranny done. MF I could have traded it in before spending close to 5k for a tranny on it.
I'm not totally inept, I can replace shit, its just I lack the diag skills if the issue isn't clear cut.
Then this guy saying I had no bad mounts. I go to NY for TG week and brought the car to Acura to fix tsb 07-060 and they're like oh btw you have a bad mount. Haha I've only been saying that to various mechanics for over a month. Got it back and it ran slammin.
I need to move out of this god foresaken hell hole.
Houston (12-23-2013)
Haha I'd love to move to socal. Been wanting to do it for a long time. Living in Maine is like being in The Shining. But yep that's the deal with Acura down in NY...lots of competition. You F up, and the customer goes elsewhere.
Look here... http://www.acuraoemparts.com/delray/jsp/home.jsp
Choose your car, then click on "Engine Mounts".
sockr1
10-01-2015 01:31 AM
