Engine light blinks at high RPM revs
It only happens when i push my engine, and speed around. It will blink and sometimes it will remain on and then a few days later the light will shut off. Anybody had this problem or got any suggestions????
and it may need a pcm update. Usually in the OBD2 world a blinking CEL means its a catalytic converter damaging fault occuring. And yes a misfire will damage the cat. but theres a couple cases of the 04-06 TL's needing the pcm update to fix the CEL blinking. I agree with ssmtl, check the basics and then if you have to then take it to the dealer to have then check it out.
HeloDown
09-08-2015 06:51 PM
