Engine leaking from passenger side. Help!
Old Mar 29, 2016 | 02:51 PM
FredV's Avatar
08 TYPE-S
I drive an 08 TLS. So I've noticed engine oil all over the passenger tired after coming from work. I'm not sure where it's coming from, maybe the engine gasket or the oil pan. Haven't quite look deeper yet but just wondering where it could actually be leaking from?
Old Mar 29, 2016 | 04:07 PM
erg69's Avatar
From what I can see from here it looks like its coming from the passenger side. Could be the oil pan, could be the common oil pump leak. If you post photos of the leak I bet you will get help on how to fix it.
Old Mar 29, 2016 | 04:31 PM
Turbonut's Avatar
Engine oil? Oil filter, gasket or filter ruptured?
Grease, CV joint?
Old Mar 29, 2016 | 06:40 PM
Will Y.'s Avatar
Registered but harmless
If it isn't engine oil, it might be power steering fluid from the reservoir or a bad hose.
You'd get some whine on turning the wheels if it's leaking power steering fluid, though.
Old Mar 29, 2016 | 07:30 PM
pohljm's Avatar
need more info + pics
gavriil
Aug 20, 2025 04:43 PM
dylankerns
Apr 29, 2021 03:39 PM
Scottod102
Mar 8, 2016 10:14 AM
Kesler123
2G TSX Problems & Fixes
Feb 26, 2016 12:30 PM
LipJones
Feb 26, 2016 05:50 AM
