Engine grinding noise
Old Jan 25, 2011 | 01:24 PM
std570's Avatar
3rd Gear
Unhappy Engine grinding noise
Here is the problem...
Whenever i rev up and release the gas real quick, it sounds like metal is grinding in the engine. It happens for a split second, around 2k-4k RPM. It is a really sharp sound, like when u grind metal on a grinding wheel. It doesn't happen when i slowly rev it up.
I thought it could be from the power steering pump, when its cold outside it doesn't sounds so good. I believe I need to change the O ring then that will solve the Power Steering noise. But the grinding noise still sounds when the engine is warm up and the power steering noise stopped.
It is kinda hard to trouble shoot by myself, if I had someone step on the gas while i listen to the noise, I may hopefully find the vicinity of the problem.
Any input is really appreciated. I have an '04 TL, MT with roughly 78K miles
Old Jan 25, 2011 | 02:47 PM
pohljm's Avatar
sounds like it could be a heat shield rattling, at least thats what some others have found. Not sure what heat shield is typically the culprit though. check the ones around your cats.
Old Jan 25, 2011 | 03:48 PM
std570's Avatar
3rd Gear
Cool...thanks for the input...ill check it out
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
Frathora
Sep 28, 2015 11:29 PM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
