Engine Crackle
Engine Crackle
My TL has an occasional engine crackle sound, but only when it's cold and I get up to 45-50 MPH. Has anybody else had this? I've been using Techron Concentrate Plus at the last few oil changes, but the sound still shows up now and then. I'm thinking of trying Redline SI-1 or Gumout All In One or Regane products. What do you think?
Welcome to the Zine!! It's hard to diagnose sounds over the internet.... What do you mean by crackle? When I hear that word I think fire. Hopefully your car isn't on fire but if it is then problem solved
It's like a tick, but it's not exactly an engine knock tick. I've heard of the Vtech noise or crackle, and that could be it. I'm also wondering if it's the belt tensioner because I've heard of a crackle or marble sound that can develop in that when it's cold. I don't have a super charger.
justnspace (07-03-2013)
MMkay.
Is it only between those speeds?
Is there a certain RPM that you hear the sound?
Is it only under load,or will the sound occur at the certain RPM in Park or Neutral?
P.S : Additives suck.
j/k Sometimes different fluids can help. But as far as fuel injector cleaner and "oil treatments"...meh :/ I don't feel so strongly about those as i do about using the correct oil and premium fuel grade. I used the Lucas Oil Stabilizer in my old CL with over 200k just to quiet down the valves cause i didn't want to do a valve adjustment. It's like honey and it gunked up the insides, that's all they're good for.
To each their own.
To each their own.
Sorry about my description of the sound. I am just trying to tell you how it sounds to me. I guess you would call a ticking sound. It does not happen at idle. It's only when I get up to around that speed range and it happens under load or coasting. But it usually goes away when the engine gets warmed up. I realize it's hard to analyze this over the internet, but I'm just trying to see if anyone has any ideas or has had it happen to them. I'm not pouring that many fluids in my gas tank, just the Techron at each of the last 2 oil changes. I have my oil changed at my local Acura dealership and I've been using the Costco premium Clean Power gas. Sorry again for the confusion.
It does sound like rocks in a tin can. I've asked my local Acura dealer mechanic about the intermediate heat shield issue and he said the 2008's don't have the problem, but I think I'll take a look or have them do it.
MMkay.
That's true. But it could happen. Honestly, check them yourself if at all possible. It's a waste of money to have them replace the shields if that is the problem. You can easily get a couple of big clamps and wrap them around yourself. We do it all the time at the shop because the little bolts that holds both shields together rot out.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
