Engine Coolant below MIN~!?
Old Jan 21, 2007 | 12:27 PM
crzygosu87's Avatar
Down for a photoshoot?
I have a 06 3g TL that i just purchased about two months ago. This morning I was checking the engine coolant level on my mom's 06 Highlander and saw that it was half full ... yet my mom was afraid that there might be something wrong with the car since it went down since she first bought the car. So, in showing her that everything was fine I opened up my hood to compare coolant levels and show that it was fine as long as the coolant level was in between the MAX and MIN marks ... however, shockingly I looked down at my coolant reservoir to see that it was BELOW THE MIN MARK ... AND I BOUGHT THE CAR ONLY 2 MONTHS AGO! I even took in the car to get it serviced only two weeks ago at Cerritos Acura because of some weird engine noise in the morning when it was cold ... yet they just returned the car saying that everything was fine and nothing could be reproduced by their technicians ... SACK OF BS ... so now I can't even drive my car @_____@
im assuming theres something DEFINITELY wrong when your engine coolant level is below the MIN mark on a practically NEW car??? someone please enlighten me ... I'm definitely frustrated right now
Old Jan 21, 2007 | 03:11 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
Nothing is wrong with the car, from the factory the car comes a little above the min. mark if none is added at pdi then it will be low. Engine coolant does go low once you drive the car and you have to fill it every once in a while, the resevoir is just there to keep the radiator at maximum level and give it coolant if it needs it. It sucks down the fluid you might have a leak or you definetely have a problem if the resevoir is empty and you take off the radiator cap and your radiator is empty, but from what you are saying is completely normal and top off the resevoir. The dealer only fills or tops of you fluid if they are performing an oil change or if they are told that they have to top off every cars fluids, but you can bring your car to the dealership that you purchased it and ask why they didnt top off your fluid during pdi if you are concerned and pissed about it because that should be have been done!
Old Jan 21, 2007 | 05:12 PM
crzygosu87's Avatar
Thanks for the info! I'm relieved to hear that it's normal WHEWWWW ... as for the dealer, yeah I'll just let them know that it has not been filled ... otherwise not a big deal
THANKS FOR THE REASSURANCE
Old Jan 24, 2007 | 10:08 AM
Actuary's Avatar
18,000mi. 29000km
yeah mmy brand new baby was below MIN first time. Dealaer said at factory, they fill barely up to min.
Old May 11, 2007 | 12:22 AM
crzygosu87's Avatar
sorry guys ... have to ask again lol
... recently, the past couple days, it's been over 90 degrees F in Socal ... is this justifiable though? @___@
Old May 11, 2007 | 08:26 AM
crzygosu87's Avatar
i also checked the radiator this morning, and it is filled to the brim with coolant which is a relief ... should I just purchase some new coolant, and that is it?
Old May 11, 2007 | 12:06 PM
JDM5lugHatch's Avatar
Now with i-Vtec
Noticed when I had my '05 that the coolant was low too. Picked up some coolant from acura and topped it off. Just make sure that you use Acura coolant.
Old May 11, 2007 | 12:18 PM
Will Y.'s Avatar
Registered but harmless
Yes. Add coolant to the "max" line on the overflow reservoir when the engine is cold.
The radiator should be always be full if there is some fluid in the overflow bottle.
Old May 11, 2007 | 07:49 PM
Damn thats low, like said above add coolant and watch how fast it dissappears, eventually i will start to go down which is normal, but if i were you i would watch it.
Old May 11, 2007 | 08:05 PM
Kracker's Avatar
05 TL
The gnomes will take it away.
I put in distilled water to get it between min and max..
Old May 11, 2007 | 08:12 PM
crzygosu87's Avatar
Cool thanks guys! I purchased a bottle of acura coolant on the way back home and filled it up
Old May 11, 2007 | 11:01 PM
Atrain's Avatar
Thumbs up Engines don't consume coolant...
If you are losing coolant it is going somewhere internal or leaking externally. Engines don't consume coolant. You would have to pretty hot to burn off any water.
Only use distilled water if you are just topping it off without anti-freeze.
Keep an eye on the amount you are losing.
If it makes you feel any better my '05 is the same way. It is below the MIN line.
A-Train
cycdaniel
Dec 17, 2019 10:58 AM
merc009
Jan 27, 2016 10:34 AM
01CLOwner
Oct 9, 2015 01:07 PM
ghuns
Sep 16, 2015 04:26 PM
HeloDown
Sep 8, 2015 06:51 PM
