Engine Coolant
Old Aug 8, 2007 | 06:00 PM
aSPECtL06's Avatar
Engine Coolant
What level does everyone maintain their engine coolant at? Between the minimum and maximum level? Or what? Mine is currently at the minimum line or a little above it...just looking for some suggestions. Thanks.
Old Aug 8, 2007 | 06:17 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
Its best to keep it between minimum and maximum level!
Old Aug 9, 2007 | 08:26 PM
aSPECtL06's Avatar
lmao, i know that but like where do you maintain it? like exactly halfway between the two or what? and what type of coolant do you use? Honda Long life antifreeze?
Old Aug 9, 2007 | 08:47 PM
Exactly halfway between the two, use honda genuine coolant!
Old Aug 9, 2007 | 09:52 PM
6spMike's Avatar
Mike's Silver Bullet
It's not that critical; anywhere between the 2 is fine.
Old Aug 10, 2007 | 12:04 AM
pohljm's Avatar
maintain it at the minimum level, those ounces weigh somethin!
Old Aug 10, 2007 | 12:34 AM
aSPECtL06's Avatar
everybody uses honda genuine coolant?
Old Aug 10, 2007 | 11:58 AM
Will Y.'s Avatar
Registered but harmless
And my mechanic and I both prefer filling the overflow tank right to the max line- it's easier to see if a leak or unusual consumption should develop.
Historically, coolant is added maybe once a year on my cars, and usually no more than a couple of cups worth. If the coolant level starts dropping visibly between fuel stops, something needs to be corrected.
Old Aug 13, 2007 | 01:35 AM
aSPECtL06's Avatar
Where can I buy this honda genuine coolant?
Old Aug 13, 2007 | 02:20 AM
01tl4tl's Avatar
Honda would have it or check parts stores- read bottle carefully
often say exceeds acura honda toyota spec
Old Aug 13, 2007 | 11:43 PM
aSPECtL06's Avatar
Anybody have a picture of the bottle by any chance?
Old Aug 18, 2007 | 11:00 AM
Pat04TL's Avatar
Google "Honda Antifreeze/Coolant Type 2" and you'll see what you need.
Old Aug 19, 2007 | 06:52 PM
wasupdog's Avatar
My Garage not
u can buy the coolant at any honda/acura dealership. strangely enough it's cheaper at the acura dealership cus i think the honda dealer across the street from me is a rip off joint.
keep in mind when u fill the overflow tank that depending on how hot or cold your car is the levels will be different. if u just turned the car off the coolant will show up at the highest level, so if you're filling the car after it's settled and is dead cold i wouldn't fill it up to the top. i checked how high it was after my car was hot and then just added a little bit from there.
SidhuSaaB
May 30, 2020 12:40 AM
01CLOwner
Oct 9, 2015 01:07 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
ghuns
Sep 16, 2015 04:26 PM
