Engine code
Old May 24, 2013 | 01:46 PM
Mahmoud Hussein Moussa's Avatar
Engine code
just bought Acura TL,,,,,,,,196k Acura TL 2004. transmission act werid it works fine when car is cold but it slips once car is warm but 2 days ago i left car on for around 25 minutes and the transmission was working fine so i don't understand is the transmission done should i rebuild it or what is going on. also the car misfire some some reason i just changed the spark plugs to "NGK LASER IRIDIUM Spark Plug IZFR6K-11 # 6994" the old one when i took them out they were rusty and is was squeaking while i was taking them off. after i change them the car still miss fire for some reason but it ideal on normal base on .85 RP. i just bought
D900 engine code scan and it gave me those codes.
P0134 2/2
92237 1/2
i hope some one can help me i have tools i am willing to fix as much as i can before sending it to the mechanic if i must.
Thank you,
Old May 24, 2013 | 02:07 PM
p0134 2/2 G
02 sensor circuit no Activity Detected (B-ank 1 sensor 1)
P2237 1/2 G
02 sensor positive C- urrent control Circuit/ open (Bnak 1 sensor 1)
M.A.P ....29Kpa
En&Speed 753.19 Rpm
Spark Adv.... 9.5BTDC
I.A.T... 30.0C
TPS.... 14.11%
Old May 24, 2013 | 04:31 PM
if some one can tell me what what parts i need to buy and what is place buy to buy them and if there is topic on how to do it.
Old May 25, 2013 | 05:56 PM
dannyz's Avatar
TLicious Type S
Bro, you've started at least 4 threads about your transmission problem. We can't diagnose or fix it for you from a distance. There is a ton of information about transmission problems--dozens of threads with different issues and solutions. I suggest you get to work and search and learn about your car and it's issues, and cease starting a new thread for every question--you'll learn more, get better results, and get flamed less.
With that said, and in the interest of helping you, our TLs can have some transmission issues--especially the earlier 3G years like yours. So start with this:
1. Replace your 3rd and 4th gear pressure switches. These switches can cause shifting problems, and eventual transmission failure. Here's a DIY, or pay someone. https://acurazine.com/forums/3g-tl-2004-2008-93/110-b-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2007-2008-a-840630/
2. Start replacing your ATF (auto trans fluid). The experts here swear by DEX3 based fluids (Redline, etc.) because it has fewer friction modifiers (FMs) that stock Honda fluid so there is less time slipping (and wearing) during the shift. Three drain and fill changes replaces most of the fluid. They recommend doing this over time--so 1x3 means draining out 3 quarts, once. You can do this three times over a few months to gradually replace the fluid. Since you have an older car, I would suggest going very gradually.
If these things don't work, you may simply have a worn out transmission. 196K is a lot of miles, and if the transmission wasn't cared for in the ways described above, it may be worn out. If this is the case, you'll need to find a good shop to rebuild it.
Good luck!
Old May 25, 2013 | 07:34 PM
Slpr04UA6's Avatar
-------Tim-------
^Good info stated above!
Yikes
May 3, 2021 04:29 PM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
