Electrical probs after replacing nav drive
Old May 23, 2013 | 10:10 PM
vmodi89's Avatar
07 WDP TL Type S
So my navigation drive died about 6 months ago, so I finally sent the drive out to Alpine for service. I received the drive back today and plugged it in just to see if it worked; it did.
So, I went ahead and bolted the drive in properly and then cleaned up some extra wires I had in the trunk. I reassembled everything and went to start the car; the alarm starts going off as I try to start the car. I got the alarm to turn off, turned the key back to the "off" position, and tried again. The car turned on as normal. Keep in mind, I do have an aftermarket Compustar 2 way remote start/alarm system.
I turned the car back off and noticed that my navigation drive doesnt seem to be working, the dome lights that are supposed to come on when I open the doors aren't working, and the factory key remote is not unlocking/locking the doors, and the door lock button on the inside of the door doesnt work either. I tried to lock and unlock the car using the Compustar remote, which also does not lock or unlock the doors.
I turn the key back to the 'on' position to turn the car on; the dome lights come on, the doors unlock and lock.
I don't know how to get the door locks working properly again. When the car is off, I cant lock or unlock doors, which means I manually have to go to each door and lock it from the inside.
My navigation also doesnt turn on, the interior lights dont automatically turn on unless the car is on, but I can turn on the map lights manually. Also, randomly my "XM" button on my radio isnt switching to XM, which worked fine until now. And, when I turn off the car, my temperature needle and my RPM needle stay at the place they are at when I stop the car, and dont return all the way to the bottom as usual.
Of course it started to rain at this time, so i couldnt do much troubleshooting.
Any ideas?
Old May 24, 2013 | 08:10 AM
flyromeo3's Avatar
All those components are controlled by the MICU which is integrated in the fuse box , drivers kick panel.
Did you unplug the nav drive unit and see if all functions work normally?
Where are these wires that you cleaned up?
Old May 24, 2013 | 10:03 AM
vmodi89's Avatar
07 WDP TL Type S
hey flyromeo, thanks for replying so soon. Turned out, since I didnt unplug the battery when I was reinstalling the navi drive, i blew the #9 fuse, the 7.5A "backup" fuse. I replaced that, and its all set now, fixed alllll my problems. Damn that was aggravating trying to figure it out!
Old May 24, 2013 | 03:48 PM
Mike420TL's Avatar
Good to know that I need to unplug battery b4 installing fixed DVD drive.. How long once they received it did it take to fix and ship back to you? Did they describe what was wrong and what they fixed?? Thanks
Old May 26, 2013 | 08:00 AM
flyromeo3's Avatar
I know the feeling. I had a leak in my windshield one time which caused some water to get onto the fuse box / MICU which caused all sorts of electrical issues.
Thankfully it dried out and no permanent damage was done.
Had to re-seal the windshield too.
Feb 25, 2020 09:57 AM
ibGTV
Sep 28, 2015 03:40 AM
andysinnh
Sep 5, 2015 11:38 PM
asahrts
Sep 4, 2015 05:55 PM
Aug 30, 2015 02:39 PM
