Engine bogs under electrical load
Old Nov 16, 2013 | 11:43 AM
04 TL 04's Avatar
Hey guys, I have been having this problem with my TL where the engine bogs under certain electrical situations. When I start the car and after I switch it to drive or reverse still holding the brake the RPM's go down a few hundred rpm and the engine shakes the car for a few seconds until I accelerate. When I am stopped (In neutral, drive, or reverse) and switch on the A/C, roll up windows, or turn the steering wheel this will cause the engine to bog down further for a few seconds.
I am hoping this is an easy fix, any help would be appreciated.
-I feel like one of my engine mounts might be broken as well, im not sure if this would contribute to this problem because some of them are vacuumed?
-Alternator problem?
-electrical short?
Old Nov 16, 2013 | 12:58 PM
mzilvar's Avatar
Sounds like it might be a problem with the idle learn procedure, was the battery disconnected recently?
You could disconnect the battery, leave it off for about 10 - 15 minutes then reconnect it and start the car. Leave the A/C off and all of the electronics in the car (radio/etc) and let the car idle without turning the steering wheel for about 10-15 minutes.
This is so it can learn the idle position of the throttle body, afterwards your problem might be gone if it was a problem with the idle learn.
uzzmaan
Aug 4, 2025 08:29 AM
Feb 25, 2020 09:57 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
