Engine backfire?
Old Jul 24, 2006 | 10:07 PM
dragonlord's Avatar
Engine backfire?
Has anyone else had this problem? I was on the freeway, put it down for passing gear, it downshifted, but when it upshifted it sounded like it backfired throught the intake. It happened again about 10 mins later, same situation. I got to my stop and checked the CAI, nothing loose and filter still on.
Now I'm scared to jump on it again. Any suggestions?
Old Jul 25, 2006 | 11:23 PM
dragonlord's Avatar
Old Jul 31, 2006 | 10:18 PM
dragonlord's Avatar
No one else has had this problem?
Old Aug 1, 2006 | 10:35 AM
CobraGuy's Avatar
Sounds like the car is going instantly lean when you hit the throttle. Your CAI could indeed be contributing to this. If you're sure you don't have any leaks in the CAI, the only other thing I could suggest is put the stock intake back on it and see if that fixes it. If it does, you know where to look for your problem. If it doesn't, take it in and have it diagnosed. It could be several different issues.
Old Aug 4, 2006 | 12:25 PM
rwholst's Avatar
4th Gear
I have experinced this exact problem in the exact same situation. Mine is a 06 Tl Stock... I have no idea what it is... I have 6000 Miles now.
Old Aug 4, 2006 | 05:26 PM
dragonlord's Avatar
Have you taken it into the dealer yet?
Old Aug 4, 2006 | 06:10 PM
JDM5lugHatch's Avatar
Now with i-Vtec
It's normal or so it seems to be (seems like a lot of odd things on this car have become known as normal to me... ha). I know that I can repeat it at will whenever I want and it's usually around the same RPM's and a full throttle shift early in the rpms. Both Michael Benz and myself have discussed this we both were at a loss. However, it may have something to do with the drive by wire system. I have experienced it well before I ever put an intake on the car running the stock air box. So this is not because of the intake. Always run 93 or higher as well (94 when it was available around here and it still happened).
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
