Emu
Old Feb 4, 2013 | 11:40 AM
Jazz O's Avatar
Emu
MY door locks turn signal and alarm just went out. i took it to a electrician. was told that it may be the EMU. a day later it came back on like it never went out. has anyone ever had this problem... HELP ME
Old Feb 4, 2013 | 01:16 PM
350's Avatar
350
My first ricer
Was the battery low? I didn't have that exact issue but my car seemed possessed when it had a low battery then was back to normal after a jump.
Old Feb 4, 2013 | 01:17 PM
how old is your battery?
Old Feb 4, 2013 | 01:20 PM
SharksBreath's Avatar
BANNED
Old Feb 4, 2013 | 01:21 PM
at Emu.
Old Feb 4, 2013 | 01:22 PM
Jazz O's Avatar
Battery relatively New about Two months old now
Old Feb 4, 2013 | 01:24 PM
Jazz O's Avatar
Not at all Bro... I love my Babygirl i need to get her right again... Help Me
Old Feb 4, 2013 | 01:26 PM
Jazz O's Avatar
this problem started last week. when i got to the electrician she started acting normal. then this morning the problem reaccured.
Old Feb 4, 2013 | 01:27 PM
BANNED
Old Feb 4, 2013 | 01:28 PM
rockstar143's Avatar
I had a short on my fuse #6 that killed all that...windows, interior lighting, keyless entry, alarm...EVERYTHING. The short was my problem but if you'd done (or previous owner) any lighting wiring, I'd check your work.
Fuse 6 kills power to all that stuff. Don't fret though...
Old Feb 4, 2013 | 01:35 PM
Jazz O's Avatar
like i said, all this started last week, for about a day. then everything went back to proper working conditions. then again this morning Everthing went back out. Can this Be the ECU?
Old Feb 4, 2013 | 01:49 PM
Jazz O's Avatar
Rockstar... what do yu think? Can it Be My ECU?
Old Feb 4, 2013 | 01:51 PM
BANNED
^get off of this ECU thing you're stuck on.
check fuse#6 like rockstar pointed out.
Old Feb 4, 2013 | 02:03 PM
Jazz O's Avatar
[quote=SharksBreath;14301050]^get off of this ECU thing you're stuck on.
check fuse#6 like rockstar pointed out.[/quote
I got that part. just wanna rule out the ECU since that is something that require me taking it to a Acura dealer, and the earliest appointment is two weeks from the day
Old Feb 4, 2013 | 02:05 PM
Jazz O's Avatar
and Rockstar did NOT rule out the ECU My Guy,, so be helpful or Get Lost
BANNED
^go ahead and rule out the ECU. it doesn't have anything to do with your symptoms.
Old Feb 4, 2013 | 02:14 PM
Jazz O's Avatar
Good looking My Guy. I do appreciate Yu. So what do yu think my problem is due to my Symptoms\
Interior light goes out when i bulckle my Seatbelt.
No Turn signals
No inside Headlights
Old Feb 4, 2013 | 02:16 PM
BANNED
^headlights are on supposed to be on the outside of the car.
Old Feb 4, 2013 | 02:17 PM
^^^I concur. NOT ECU related...if you were getting CEL's and the car was running nuts, I'd say maybe it's ECU related.
I would really urge you to take a look at the port for fuse 6. If it's coming and going it's obviously not killing the fuse, but I bet the fuse isn't seated properly or something...change the fuse preemptively anyway to be safe. Your car modded at all?
Also, if you have a mechanic leaning toward the ECU, please get yourself a new mechanic. He doesn't know this car.
If you need to look further than a fuse, what you NEED to be thinking about is a possible issue with the MULTIPLEX UNIT. Which is behind the fuse panel. Supposedly a huge PITA to replace. ECU isn't it.
Old Feb 4, 2013 | 02:20 PM
Jazz O's Avatar
Good looking My Guy. I Do Appreciate Yu So whats my problem. here are all the Symptoms:
No turn signals
No inside head lights
Interior lights go out when i Buckle Seat Belt
No windsheild wipers on normal speed only wk on high
No door Locks
No keyless entry
No outside temp Display 3 dashes.
and the fuses all appear Good
Old Feb 4, 2013 | 02:23 PM
Jazz O's Avatar
Your Fucking Good Rockstar!! One mech did say it was the Multiplex Unit... No i have no mods. How much should this run me?
Old Feb 4, 2013 | 02:24 PM
BANNED
^my man, it honestly sounds like a bad battery or your multiplex unit got wet. is the floor wet below the steering column?
Old Feb 4, 2013 | 02:37 PM
Last I checked, I think the unit was over $200 alone, not including the labor for install. I killed the circuit that powers my door courtesy light...since that's ALL that went bad on mine (my own fault, I stripped and shorted a wire when running speaker wire) I called it a day and left it that way.
CHICKEN204
4G TL Photograph Gallery
Feb 8, 2020 07:50 PM
sj123
Sep 13, 2014 06:32 PM
Nukebug
37
Jul 2, 2013 12:39 PM
