Emu
Emu
MY door locks turn signal and alarm just went out. i took it to a electrician. was told that it may be the EMU. a day later it came back on like it never went out. has anyone ever had this problem... HELP ME
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
justnspace (02-04-2013)
BANNED
BANNED
I had a short on my fuse #6 that killed all that...windows, interior lighting, keyless entry, alarm...EVERYTHING. The short was my problem but if you'd done (or previous owner) any lighting wiring, I'd check your work.
Fuse 6 kills power to all that stuff. Don't fret though...
Jazz O (02-04-2013)
like i said, all this started last week, for about a day. then everything went back to proper working conditions. then again this morning Everthing went back out. Can this Be the ECU?
BANNED
^get off of this ECU thing you're stuck on.
check fuse#6 like rockstar pointed out.
[quote=SharksBreath;14301050]^get off of this ECU thing you're stuck on.
check fuse#6 like rockstar pointed out.[/quote
I got that part. just wanna rule out the ECU since that is something that require me taking it to a Acura dealer, and the earliest appointment is two weeks from the day
BANNED
^go ahead and rule out the ECU. it doesn't have anything to do with your symptoms.
Interior light goes out when i bulckle my Seatbelt.
No Turn signals
No inside Headlights
BANNED
^headlights are on supposed to be on the outside of the car.
^^^I concur. NOT ECU related...if you were getting CEL's and the car was running nuts, I'd say maybe it's ECU related.
I would really urge you to take a look at the port for fuse 6. If it's coming and going it's obviously not killing the fuse, but I bet the fuse isn't seated properly or something...change the fuse preemptively anyway to be safe. Your car modded at all?
Also, if you have a mechanic leaning toward the ECU, please get yourself a new mechanic. He doesn't know this car.
If you need to look further than a fuse, what you NEED to be thinking about is a possible issue with the MULTIPLEX UNIT. Which is behind the fuse panel. Supposedly a huge PITA to replace. ECU isn't it.
Jazz O (02-04-2013)
No turn signals
No inside head lights
Interior lights go out when i Buckle Seat Belt
No windsheild wipers on normal speed only wk on high
No door Locks
No keyless entry
No outside temp Display 3 dashes.
and the fuses all appear Good
rockstar143 (02-04-2013)
BANNED
^my man, it honestly sounds like a bad battery or your multiplex unit got wet. is the floor wet below the steering column?
Last I checked, I think the unit was over $200 alone, not including the labor for install. I killed the circuit that powers my door courtesy light...since that's ALL that went bad on mine (my own fault, I stripped and shorted a wire when running speaker wire) I called it a day and left it that way.
sj123
09-13-2014 06:32 PM
Nukebug
37
07-02-2013 12:39 PM
