ECU kill switch
ECU kill switch
Looked over the forums, and i couldn't find anything on this. I hate having to pull my negative battery cable off and leave it overnight to reset the ECU. Is is possible to Put a switch between the main power wire to the ECU to be able to control it from inside the vehicle?
groundhog day?
get the helms manual- it will have the schematic- then- when you trace the wires,( plug ) ( it will undoubtedly link to the fuse box) CAREFULLY and properly extend it to where you want it positioned with high quality switch ( using a bosch or hella brand 4 prong relay ( same amps as the fuse used in fusebox) than have it rerouted back to ecu. So, the wire ( better to interrupt a critical ground for ecu than hot. ( in my opinion ) then no amperage issue with switch can arise( blowing, burning, melting) Just- negative continuity is interrupted at your command. But you better know what your doing. I made a pig tail fuse pull for my ecu fuse that I pull out ( keychain style ) to help secure....In my 02 accord v6- not same as a kill switch- but functions similarly.
placebo affect
while throttle response doesnt get affected nearly as much as an automatic, resetting the ECU still clears codes and such.
and remember OP, it doesnt take all night.
disconnect the negative terminal from the battery. I do it for less than 5 mins.
and my codes are clear and i have to input radio/nav codes.
d1sturb3d119 (01-12-2013)
ECU reset is placebo in my opinion... I accidentally drained my battery by leaving my doors open for a long time while I was installing my USASpec, and when I jumped the battery, I had to put in my radio code. I completely forgot that doing so would "reset the ECU", and the car felt no different than it did before...
justnspace (01-11-2013)
Every time I pull my ECU fuse, the fuel trims increase significantly and then taper back down after driving the car around. I read them with a generic ELM327 OBD2 scantool off ebay.
xsilverhawkx
09-28-2015 06:51 PM
