Ecm?
Old Feb 4, 2013 | 12:20 PM
Jazz O's Avatar
Ecm?
What problems will a failing ECM produce
Old Feb 4, 2013 | 12:42 PM
flyromeo3's Avatar
what problems are you encountering
Old Feb 4, 2013 | 01:04 PM
Jazz O's Avatar
As you appear so much more knowledgable in this subject. My door locks, turn signals inside headlights, and interior lights stopped functioning properly. I do not have no warning signs or check engine lighs on the dashboard. and i recently checked all of the fuses all working. Can this be My ECM?
Old Feb 4, 2013 | 01:06 PM
Jazz O's Avatar
I mean ECU its a 04 tl with 151000 mi
Old Feb 4, 2013 | 01:14 PM
how old is your battery?
Old Feb 4, 2013 | 01:29 PM
Jazz O's Avatar
two months old
Old Feb 4, 2013 | 03:23 PM
EvilVirus's Avatar
inb4dalock
Old Feb 5, 2013 | 09:09 AM
flyromeo3's Avatar
The MICU is what controls all those functions. This unit is integrated into the fuse box on drivers side foot well.
If in fact there is a problem there is a way to gather the b-codes via your MID.
Here is a picture of the drivers fuse box.
You will notice to the left side, above the blue relay, I have placed a red square.
There are two contacts in there.
You will need to get some butt connectors and attach one on each end of the wire. Youre basically making a jumper wire.
Connect each butt connector to those contacts i have squared off.
Start your car and take a look at your MID.
You should see a series of codes pop up on the display. BXXXX,
To cycle between them press the select/reset button.
Write down each code you see and post here.
turn off car and unplug the "jumper wire" from fuse panel.
Jamus22
Jun 11, 2023 10:08 AM
HeloDown
Sep 8, 2015 06:51 PM
kewlblu
Jan 7, 2008 04:04 PM
waldo69
Feb 17, 2003 04:36 PM
