E-brake assembly/replacement
Old Jan 25, 2010 | 09:50 AM
6spdtl-s's Avatar
Nismo TL yo!
I replaced my pads/rotors over the weekend and my ebrake on one side pretty much disintegrated as I took the rotor off. The assembly also came off of its mounts, clips fell and two nails (assuming holding the clips in place) fell out as well. I didnt want to risk putting it together wrong, plus I need a new ebrake pad (or do I need the whole assembly?), so I took the assembly out and just put the rotor on for the time being since it was sunday and the dealer was closed.
Bottom line: does anyone have any assembly or replacement information on 3G e-brakes? I couldnt find a thing.
thanks in advance
Old Jan 25, 2010 | 09:51 PM
6spdtl-s's Avatar
Nismo TL yo!
no one? pretty pleaseeeeeeeeeee
Old Jan 25, 2010 | 10:23 PM
nfnsquared's Avatar
Do you have all of these parts:
http://www.acurapartswarehouse.com/c...rake-shoe.html
Old Jan 26, 2010 | 10:36 AM
6spdtl-s's Avatar
Nismo TL yo!
I believe I have most of those, but I need a new brake pad so I'm not sure if I can buy that separately or have to buy part of that assembly.
Also, I was more concerned about the assembly of the brake since I dont want this coming apart while driving....that would be a wreck waiting to happen.
Old Jan 26, 2010 | 11:07 AM
nfnsquared's Avatar
Mods: This might be something for the Garage. I didn't see any scans or DIY or P-brake component repair/replacement.
There's a good picture of the P-brake components in this thread:
https://acurazine.com/forums/showthread.php?t=624404
Here are the scans for P-brake repair/replacement:
Old Jan 26, 2010 | 11:42 AM
6spdtl-s's Avatar
Nismo TL yo!
cant see this stuff at work, but I appreciate it. I'll take a look at it later.
Old May 6, 2010 | 01:35 PM
swoosh's Avatar
takin care of Business in
dude great info !!!
when my parking brake started to act a little weird i tightened the cable in the cabin....and its fine now....if it acts crazy again then will tighten the cable in the rear hub....next step is to replace them.....
but i hope you know how to tighten the brake cable....if not lemme know and will put the info up
Old Apr 17, 2016 | 12:28 AM
robocam's Avatar
U-clip
How do you remove the U-clip? (it's attached to one of the brake shoes with a wave washer)
Old Apr 19, 2016 | 08:58 AM
BreezyTL's Avatar
grab the tip of the pin with a pliers and twist. (item 16) in the picture above correct?
Old Apr 24, 2016 | 11:13 AM
paperboy42190's Avatar
there are special pliers to get those pins, but needle nose usually works fine, just a bit harder to grab and twist
r3mix3r
Jan 9, 2008 09:14 PM
teh CL
Jan 27, 2005 11:29 AM
white99cl2.3
Dec 4, 2004 10:41 PM
ju5tchi11in
Feb 18, 2004 11:33 PM
Nashua_Night_Hawk
Feb 23, 2003 07:38 PM
