AT or driveshaft whistling during acceleration in 1st + 2nd
Has anyone heard this noise before? I suspect a main shaft bearing or bad propellor shaft. It occurs during acceleration in 1st and 2nd gears. I changed my trans fluid but that had no effect on the noise. Thanks
https://we.tl/t-J6jn3EG4OO
(scroll down to download button)
depending on severity it could be fine and normal, or failing internal bearings inside the trans. Make sure fluid is replaced regularly and if you have an 04-06 change your trans filter.
