Driver's side power window problem
Old 01-14-2013 | 12:55 PM
fsapienza's Avatar
Thumbs up Driver's side power window problem
My driver's side window is currently rolled up and when I try to roll it down it will only go down about an inch. I can then roll it back closed. A few days ago I rolled it up and it was moving very slowly up, so I thought the motor may be dying. It rolled down a little one more time, and it wouldn't go all the way back up, so I manually pulled it to close it completely. It's current state is as I stated above, and I can hear the motor working to move it the small amount it currently moves. I originally thought the motor had died but based on the current state, I don't think thats the problem.
Any suggestions/ anyone have this problem before?
Old 01-15-2013 | 09:34 PM
LoveMyTL-S's Avatar
The power window may need resetting or the regulator needs adjusting/replacing. I'd try the reset first. Check out this thread and scroll down to the reset instuctions:
https://acurazine.com/forums/3g-tl-2004-2008-93/front-rear-door-panel-handles-wstrip-glass-window-regulator-removal-3g-garage-f-016-a-603296/
Good luck.......
Old 02-10-2013 | 04:27 PM
dhayes88's Avatar
I'm having a problem with my 04 TL. I had some door speakers put in a few months ago and now the windows/sunroof will not roll down. (They are stuck in the up position). Any ideas? I've searched alot and can't seem to find anything. Thanks
02-25-2020 09:57 AM
jblessing
08-08-2018 09:43 PM
acura_dipset_tl
01-01-2016 03:02 PM
PortlandRL
09-14-2015 12:01 PM
ahsm
09-09-2015 08:35 AM
Quick Reply: Driver's side power window problem
