Drivers side door
Old Jun 4, 2014 | 08:05 PM
LAGS8005's Avatar
StephTL2580
Drivers side door
Hey guys and/or gals.
About a 2 months ago, I decided one day to move my seat back a little. Lo and behold it doesn't work. I press the memory buttons and nothing. I try to slide it back and forth and nothing. I try to recline it and nada. The only thing that works is the lumbar. I have seen quite a few posts about the teeth being stuck, check with a flat screwdriver. I haven't done that yet. I did check all the fuses per the manuals guide but that didn't fix it either. I am dreading taking it to the stealership but I would only take it there to get a part or the name of the exact part unless one of ya'll know exactly what it is.
Any input would be greatly appreciated!
-Steph
Old Jun 5, 2014 | 02:34 AM
Will Y.'s Avatar
Registered but harmless
Do the exterior mirrors or windshield washer work?
If not, check fuse #20 in the under-dash fuse box-- replace the 7.5 amp with a 10 amp per the TSB.
If they do work, it sounds more like a fuse/power issue than mechanical problem with the seat. Check for any fuse that relates to the driver's seat.
Old Jul 11, 2014 | 08:54 AM
LAGS8005's Avatar
StephTL2580
So maybe this sheds some more light on my situation. There is power going to the control module but none of out any of the pins.
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
govtcheez
Oct 1, 2015 12:21 AM
hand123
Sep 10, 2015 09:27 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
