Drivers side door
StephTL2580
Drivers side door
Hey guys and/or gals.
About a 2 months ago, I decided one day to move my seat back a little. Lo and behold it doesn't work. I press the memory buttons and nothing. I try to slide it back and forth and nothing. I try to recline it and nada. The only thing that works is the lumbar. I have seen quite a few posts about the teeth being stuck, check with a flat screwdriver. I haven't done that yet. I did check all the fuses per the manuals guide but that didn't fix it either. I am dreading taking it to the stealership but I would only take it there to get a part or the name of the exact part unless one of ya'll know exactly what it is.
Any input would be greatly appreciated!
-Steph
-Steph
Registered but harmless
Received 1,150 Likes
If not, check fuse #20 in the under-dash fuse box-- replace the 7.5 amp with a 10 amp per the TSB.
If they do work, it sounds more like a fuse/power issue than mechanical problem with the seat. Check for any fuse that relates to the driver's seat.
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
